ToyotaOff-Road.com
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 26
Thread: 2nd Gen Rear Brakes
  1. #1
    Name
    Roger
    Join Date
    Jul 2010
    Location
    Morning Glory, TX
    Posts
    434
    80 P/U - Clockwork Orange
    2009 Taco Darn Near Stock
    2nd Gen Rear Brakes
    I thought I would put the references here so that if and when you do yours it will be in one place.
    Components and Disassembly
    http://www.ncttora.com/fsm/05+/data/...a/04201010.pdf
    Inspection and Reassembly
    http://www.ncttora.com/fsm/05+/data/...06ta/04201.pdf
    Brake Drum Installation and Brake Bleed
    http://www.ncttora.com/fsm/05+/data/...6ta/042010.pdf
    So, I'm about to put my rear brakes back on the Taco and would like to get rid of the Cast Iron aftermarket wheel cylinders and can't find a rebuild kit for the OEM (aluminum Advics 15/16" bore); The only reason I currently have cast iron ones is that is all Broker and I could find the day I blew one - wheel cylinder that is. Has anyone found one a rebuild kit for the Advics? TIA
    They use AISIN rubber peices.
    The external rubber cover is AISIN p/n 144511-10050.
    The piston seal is AISIN p/n 144531-24010
    Before I finished whining... I think I have found what I need - rebuild kit for a T100
    Summit Racing
    http://www.summitracing.com/parts/DHB-352126/
    Oreilly
    http://www.oreillyauto.com/site/c/se...989&vi=1272260
    PartsGeek.com
    http://www.partsgeek.com/catalog/198...epair_kit.html
  2. #2
    Name
    Roger
    Join Date
    Jul 2010
    Location
    Morning Glory, TX
    Posts
    434
    The Dorman Part number for the 15/16" Al Wheel Cyl rebuild kit is 352126
    The application list is here:
    http://www.rbinc.com/da-32273-352126.aspx
    It only lists 89-02 4runners and 93-98 T100s - strange that NO ONE lists the correct one for a 2009 Taco and want you to replace it with the cast iron unit. - I personally like some of the details to the OE casting like the two 'drip bumps.' Oh well, I hope this helps one person in not having to go through the online ordering of kits that don't work and the local wild goose chase I've been on!
    Oh yeah, if you haven't done this before, soak the piston seals in DOT 3 for a couple of hours before you try to stretch them on to the pistons.
  3. #3
    Name
    Roger
    Join Date
    Jul 2010
    Location
    Morning Glory, TX
    Posts
    434
    One last thing - you could get an OEM wheel cylinder for about $40 each online but call me 'challenged' these days and I thought an extra $6 kit in my tool box for trips wouldn't be a bad thing to bring. Hell, I've toted a CV around that I have never used (stopped carrying that thing around).
  4. #4
    $6 kit is better than a 3hr drive for parts. But u did get to drive it home
    Brian: Do you listen to yourself when you talk?
    Peter: I drift in and out.
  5. #5
    Name
    Roger
    Join Date
    Jul 2010
    Location
    Morning Glory, TX
    Posts
    434
    Quote Originally Posted by Broker View Post
    True! Thanks again!
  6. #6
    Name
    Roger
    Join Date
    Jul 2010
    Location
    Morning Glory, TX
    Posts
    434
    How's the 'runner coming along?
  7. #7
    Join Date
    Jun 2010
    Posts
    3,060
    How about a rear disk conversion?
  8. #8
    Name
    Roger
    Join Date
    Jul 2010
    Location
    Morning Glory, TX
    Posts
    434
    Same reason this isn't part of my truck!
  9. #9
    Name
    Roger
    Join Date
    Jul 2010
    Location
    Morning Glory, TX
    Posts
    434
    Would almost justify this!
  10. #10
    Join Date
    Jun 2010
    Posts
    3,060
    I'll be back in a moment.. cold shower required.
  11. #11
    Name
    Roger
    Join Date
    Jul 2010
    Location
    Morning Glory, TX
    Posts
    434
  12. #12
    Quote Originally Posted by TacoXpo View Post
    Picking it up in two weeks then driving cross country with it, got the timing belt and water pump changed out on it last week. Found the leak it had. The water pump was shot on it.
    I'll agree w Sean on the cold shower. If the Tacoma wasn't going LT the runner would. I just couldn't justify LT on the runner.
  13. #13
    Name
    Roger
    Join Date
    Jul 2010
    Location
    Morning Glory, TX
    Posts
    434
    Whos LT do you plan on picking up?
  14. #14
    I was checking out camburg at the Offroad expo, and will prob end up doing a custom spring under bed cage in the rear. Debating if I wanna just sell the whole bed while it's nice and straight or try to keep stock look as long as possible. I like the stock look but have a feeling that once that first cut goes into the bed I'll want to tube the whole thing.
  15. #15
    Name
    Roger
    Join Date
    Jul 2010
    Location
    Morning Glory, TX
    Posts
    434
    I like Camburg stuff. TC is probably the most well developed if you look at the coil gussets and stuff but you could do the same with Camburg stuff. I would sell the bed complete. It could pay for the fiberglass and 1/2 the bed cage! Once you cut it, well, you will have a $100 bed!
  16. #16
    Big tires little bed taco4x4rar's Avatar
    Name
    Randy
    Join Date
    Jun 2010
    Location
    bum fuck Texas
    Posts
    1,584
    2006 tacoma
    1992 broke ass chevy
    A hundred bucks hell i Should sell mine
    When times get tough - fat people get skinny and skinny people die.
  17. #17
    Ill prob end up ditching the bed and mounting fiberglass fender somehow. How much would a red bed sell for u think?
  18. #18
    Name
    Roger
    Join Date
    Jul 2010
    Location
    Morning Glory, TX
    Posts
    434
    One guy here, sold his for a grand to a body shop!
  19. #19
    Name
    Roger
    Join Date
    Jul 2010
    Location
    Morning Glory, TX
    Posts
    434
    updated first post
  20. #20
    Name
    Roger
    Join Date
    Jul 2010
    Location
    Morning Glory, TX
    Posts
    434
    Someone want upgraded brakes....
+ Reply to Thread
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
