I'm hoping to help others with a how-to on installing a minor body lift (1") on the 2nd gen Tacomas since there is not much information out there on them.
I installed this kit on my truck which is a 2010 Access cab manual transmission. My truck also has a 3" suspension lift on it but that should not make any difference on the procedure I lay out below. Instructions will vary between cab sizes and there may be some additional work needed for an automatic transmission but this writeup should give you the general idea what's involved.
*I in no way take responsibility for what you do to your truck or if anything happens as a result of this mod. This is only an informative thread, please consult the Toyota FSM and/or professional mechanics if you have questions or concerns.
I installed the body lift to make room for some larger tires while being able to retain the fender flares as well as being able to clock the t-case in order to go flat belly someday. This modification was a little time consuming, I'd say around 6-7 hours if performing solo or maybe 4-5 with the help of a buddy or two.
I ordered the kit from 4crawler offroad with the following parts:
• Kit D (UHMW blocks and associated hardware)
• Kit HD (Upgrade to grade 8 hardware)
• Kit CLR black (gotta look stylish)
• Kit RAD
• Kit GAS
http://www.4crawler.com/4x4/ForSale/....shtml#Tacoma3
The kit shipped very quickly and all the products were very high quality and Roger's customer service was excellent he helped me out a bunch.
On to the nitty gritty
Tools required:
• Impact gun
• Grinding wheel
• PB blaster or equivalent
• Silicone spray lubricant
• Air/Electric Die grinder
• T55 torx bit
• Various metric/US socket sizes and extensions
• Torque wrench
• Couple short blocks of 4x4 wood
• Floor jack
• Screw drivers and pliers
The parts we will be installing
Truck it will be going on
Before we start take some fender to ground measurements for the records
Front, about 38"
Rear, about 40"
First step is to disconnect the battery negative cable and wait a few minutes for the ECU to lose it's power for the airbags, don't want an airbag going off in the middle of the install!
Don't mine my dirty engine bay, it sure needs a wash
Next step is to start disassembling the interior, this was the most time consuming part of the install. I didn't want to break or snap any of the interior plastic clips that our trucks are filled with.
Remove the dead pedal by pulling it towards the back of the truck
Pull off the door sills carefully starting at one end, they are clipped in. They are two separate pieces on for the front and one for the rear
Unscrew this little black knob from the kick panel then pull the kick panel towards the back of the truck and it will unclip
You can then peel back the carpet to find this little rubber grommet, under this is the middle cab mount bolt (behind the front tire)
Remove rear arm rest by unbolting the 4 bolts that attach it to the truck, I believe they are 10mm
Once the arm rest is out of the way you can disconnect the bracket it bolts to, there are two 12mm bolts holding this on to the cab
Remove the back seats, each seat is held in with 3 bolts all together, 12mm if I remember correctly. Peel back the carpet to access these bolts
Once the seats are out of the way you can remove the black lining/storage bins from the truck. Not sure if this was necessary but I figured I'd take it out to clean under it anyhow and it seem to make things easier.
Pop the little clips out. To do this, pop the middle up with a small flat screwdriver to disengage the clip then pry the bottom lip out of the hole
Once the lining is out it will look like this
After all that is removed peel the carpet back a little more to access these small stiffening plates that are held in by two 10mm bolts, remove the bolts and plate
Below the plate there is another small plastic grommet, that is the access to the rear cab mount bolt, remove the grommet
Next you need to remove the front grille, this is simple by unscrewing two phillips screws
and popping out two clips
Give the grill a good yank upwards and it will unclip from the headlight assemblies, careful to use equal force on each side to not snap the cheap plastic Toyota tabs.
Now that the grill is off and interior is partially removed you will have access to all the cab mount bolts.
Start loosening one side of the cab mounts (driver or passenger) leaving the nuts on and then remove the opposite side bolts completely.
Since I was by myself I had to think of interesting way to do this.
I found removing the e-brake cable from the leaf springs made it easier to get to the rear cab mount since the ebrake cable is in the way a bit. Remove with a 14mm socket
Rear cab mount is a 19mm bolt.
To hold the nut in place I used an adjustable wrench with a floor jack, this was a large metric nut and I did not have a deep well socket to fit it so the wrench worked just fine.
Middle cab mount is also 19mm bolt, I used the same method of a floor jack and adjustable wrench. Here is where having a buddy would have came in handy
Front cab mount is 14mm
Use some sockets/extensions so you don't have to take the headlights and bumper off
Make sure you wheel is straight and the bolts on the shaft are able to be accessed from the engine bay or wheel well. Remove the rubber inner flaps in the wheel well that keep mud and debris flying into your engine bay.
Loosen the steering shaft with a 14mm socket to allow it to lengthen with the lift. I also marked mine with some chalk in case it fell out, we don't want to damage the clock spring.
Once you loosen one side of the cab and remove the bolts from the other side you are ready to jack the cab up to insert the lift blocks. Check to make sure you don't have any other wiring or accessories which might be pulled tight when jacking the cab up.
