ToyotaOff-Road.com
+ Reply to Thread
Page 1 of 4 1 2 3 ... LastLast
Results 1 to 20 of 75
Thread: Armor coating options/choices
  1. #1
    Senior Member PSU Taco85's Avatar
    Name
    Anthony
    Join Date
    Sep 2011
    Location
    Southern NJ
    Age
    27
    Posts
    582
    I didn't see a good thread on painting/coating products for Armor (bumpers/sliders/skid plates, etc). I know there are alot of products available with various advantages/disadvantages to each choice.
    I'm looking for some info for what to use for front/rear bumpers specifically, but I thought this thread would be a good spot to post up different products used/tested and how they have held up to the elements and wheeling adventures.
    Here's a list I have compiled of possible products:
    Standard rattle can
    + Cheap, easy to touch up, easy to apply
    - chips easily and doesn't hold up well to scratches and the elements
    Powder coating
    + Holds up well to the elements, looks great
    - One of the more expensive options, not as easy to touch up, most people would not be able to apply themselves and have a shop do the work.
    My sliders are powdercoated and so far they have held up great for normal use
    Here is a shot of my CBI sliders I had powdercoated (by CBI)
    Rustoleum truck bed coating
    http://rustoleum.com/CBGProduct.asp?pid=367
    + cheap and readily available, easy to apply
    - not sure it would hold up in the long run
    Rustoleum rubberized undercoating
    http://www.rustoleum.com/CBGProduct.asp?pid=364
    I have used this product in my wheel wells after beating back the pinch weld, so far it's held up well to rocks/dirt/mud being flinged at it
    Duplicolor bed liner
    http://www.duplicolor.com/products/truckBedCoating/
    + Similar to powdercoating only more durable to scratches
    - expensive
    No real world experience with the product
    Line-X
    http://www.linex.com/
    - expensive
    Rhino line
    http://www.rhinovehicleprotection.com/en/page/1/Home
    - expensive
    Joe's Relentless bumper coated with Rhino line
    Herculiner
    http://www.herculiner.com/
    - expensive
    POR 15
    http://www.por15.com/
    + Hard as nails, could touch up relatively easy
    - expensive, not UV resistant and requires a top coat.
    I used POR15 on all my skids and so far I must say they are holding up well and the only spots to chip off are ones that hit some big rocks which actually took out chunks of metal from the skids .
    Here's a few shots of the POR15 in action on the skids, this stuff is tough as nails the only downside is it isn't UV resistant so a topcoat is required. For skids since they don't see the sun, no topcoat required
    Monstaliner
    http://www.monstaliner.com/
    Jeff's Relentless is coated in Monstaliner, no details on how it has held up yet on the trails.
    Raptor Liner
    http://www.u-pol.com/product-cat/83/...-bed-liner.htm
    No real experience with this product
    So let's hear your opinions, facts, stories, experience with different products and what you would recommend
  2. #2
    Member tx_shooter's Avatar
    Join Date
    May 2011
    Location
    Texas
    Posts
    113
    '06 Tacoma PreRunner
    '87 4Runner
    IMHO if the part is a high impact part (aka sliders) then rattle can is the best bet. Easy to touch up and tough if applied in multiple coats.
    If you go off roading and you don't break something or get stuck - were you really off roading???
  3. #3
    Join Date
    Jun 2010
    Posts
    3,060
    I tried this VHT Epoxy paint on my bumpers and sliders. NOT impressed. http://www.vhtpaint.com/products/epoxypaint/ after about a year (maybe 15 months) you can take your finger and wipe the bumper and get a black residue on it. At first it looked great but its not holding up to the sun.
  4. #4
    n00b Oswego's Avatar
    Name
    Dyob
    Join Date
    Jul 2010
    Location
    The armpit of America
    Posts
    633
    Rustoleum bed liner absolutely sucks.
    After seeing 2 brand new steel front bumpers (1-2 weeks old) rusting out this weekend I have made up my mind..... Front bumper powder coat...everything else gets a roller with industrial paint or spray paint.
  5. #5
    Senior Member Dark Knight's Avatar
    Join Date
    Jun 2010
    Location
    East Tennessee
    Posts
    545
    Monstaliner seems to chip easily. I believe there was to much catalyst in the pre-measured pouch that comes with the kit. I had perfect painting conditions, weather wise, and the metal was prepped as specified by the Monstaliner directions.
    I do really like how it turned out but it is just a little to crispy to not just chip off when dragged across rocks or even when the tire throws a rock up.
  6. #6
    Senior Member
    Join Date
    Aug 2011
    Posts
    269
    I've had my best luck with rubberized undercoating. Holds up better than rattle can paint to use, but touches up just as easily. Con would be that it's a bit more expensive.
    I just use black rattlecan or rubberized undercoating...whatever I happen to have around at the time I happen to be touching up...
    I do make it a point to get a nice thick coat of the rubberized stuff in areas vulnerable to rock chips. It holds up very well in areas that don't see impact often but get a lot of gravel thrown at 'em.
  7. #7
    Join Date
    Jun 2010
    Location
    East Tennessee
    Posts
    545
    the only thing I can think of that could have gone wrong is the directions specify to put a thin layer of acetone in the mixed can as a top layer so it wont "skin over" in between coats or pours into the roller pan. Maybe I could have put in to much??
  8. #8
    Name
    Roger
    Join Date
    Jul 2010
    Location
    Morning Glory, TX
    Posts
    434
    80 P/U - Clockwork Orange
    2009 Taco Darn Near Stock
    I personally like the look of the Rustolium Bedliner on my bumpers and sliders. Problem is that wax (does that even touch my truck? ) and dirt and mud are harder to clean out. I have found that Rustolium Bedliner followed by a coat of semi gloss black still gets the bedliner look but is much easier to clean.
  9. #9
    Senior Member Lrgrnr's Avatar
    Join Date
    Jul 2010
    Location
    Asheboro NC
    Age
    24
    Posts
    1,377
    Best cheapest way imo is to use 3m rubberised undercoating as a primer then top coat with good satin paint.
  10. #10
    Name
    Roger
    Join Date
    Jul 2010
    Location
    Morning Glory, TX
    Posts
    434
    Oh and did I mention that my bumper and sliders were delivered to me powder coated and it provided a great base.
  11. #11
    Join Date
    Jul 2010
    Location
    Asheboro NC
    Age
    24
    Posts
    1,377
    Quote Originally Posted by TacoXpo View Post
    Basically this
  12. #12
    Name
    Anthony
    Join Date
    Sep 2011
    Location
    Southern NJ
    Age
    27
    Posts
    582
    Cool thanks for the input
    I'm going to price out a few local powdercoaters in my area to see what they'd want to do two bumpers. Depending on that price I'll go from there!
    I'm going to use that rubberized undercoating on a few more projects I have on mind as well. The only thing ive found with that stuff is you can't apply it to thick or it never dries
  13. #13
    Senior Member 05tacoSPORT's Avatar
    Join Date
    Sep 2011
    Posts
    549
    05TeRD on 35's
    This Is what I use. I personally wouldn't powder coat if you are planning on using the armor for what it's made for. For me I apply, beat the shit out of the steel, let rust for a few weeks, sand,and paint for the next trip.
  14. #14
    Join Date
    Sep 2011
    Posts
    549
    05TeRD on 35's
    And dragging a 1k bumper with $150 worth of paint on rock hurts.
  15. #15
    Name
    Anthony
    Join Date
    Sep 2011
    Location
    Southern NJ
    Age
    27
    Posts
    582
    Quote Originally Posted by 05tacoSPORT View Post
    Yeah that's what I've been thinking but we don't have too many rocks around my area, mostly pine trees, sand, and puddles
    My thought was that maybe just sand and repaint the areas of the powdercoat that would get bashed off by obstacles with rattle can. I'm sure the high spots of the bumper wouldn't get bashed too bad would hold up a lot longer with a nice powdercoat finish
  16. #16
    Big tires little bed taco4x4rar's Avatar
    Name
    Randy
    Join Date
    Jun 2010
    Location
    bum fuck Texas
    Posts
    1,584
    2006 tacoma
    1992 broke ass chevy
    I'd stay away from the bed liners they are expensive and hard to fix. I went the cheap route with rattle cans cause they need to be repainted almost every time I go wheeling
    When times get tough - fat people get skinny and skinny people die.
  17. #17
    Fuck Off AlienXtx's Avatar
    Name
    Mr. Asshole
    Join Date
    Jun 2010
    Location
    Republic of TEXAS
    Age
    33
    Posts
    3,509
    I just use whatever frr cans of paint we have in the parts room at work?
  18. #18
    Married Man Boomtacoma01's Avatar
    Name
    Chris
    Join Date
    Jul 2010
    Location
    H-Town
    Posts
    771
    85 Yota "Lil Red"
    09 Yota "Gas Hog"
    Good ideas here. I like the idea of the paint over the bedliner. I'll be repainting my rear bumper on the tacoma in the near. I'll probably just sand, prime and paint though since I have an older beater now.
    -- Sent from my Palm Pixi using Forums
    '85 Toyota E/C - 22-RE, 4.7's and some Marlin stuff on 37's and no A/C
    Spare Parts and heavy right foot
    '09 Tacoma DC - 285/70/17 KM2's, Kings/AllPro suspension, Shrockworks bumpers and
    sliders, ATO HC Rear Bumper, LF 170's, 1911 and some ammo - DD'er
  19. #19
    Banned In DC! Pd3's Avatar
    Join Date
    Jul 2010
    Location
    Washington, DC
    Age
    41
    Posts
    524
    Krylon Satin black!
  20. #20
    Member JLink's Avatar
    Name
    Josh
    Join Date
    Jan 2011
    Location
    Ocean, NJ
    Posts
    73
    2010 Tacoma DC LB Sport
    Triumph Sprint ST 1050
    I'm not impressed with rattle can on my skids and front bumper. Skids its ok because they will get beat to shit so spray paint is the best option, but for my bumper I'd like something else. My sliders are powder coated and I'm impressed how well they are doing. My front bumper definitely doesn't take as many hits as the sliders will, so I'm thinking powder coat or maybe rhino lining for that and the same when I get a rear bumper.
+ Reply to Thread
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
