I'm planning on pulling the ADD out of my '01 Taco and swapping it with the manual hubs/diff that is currently in my '98.
I know most say that the ADD CVs are stronger than the manual CVs but I have multiple reasons for going the route I am going.
The manual hub diff under the '98 is already set up with 4:88s and a locker, so I want to keep those. Also, I like the option of being able to unlock the hubs if a CV breaks and also to avoid excessive wear on the CVs during on highway driving.
I don't believe this part of the swap will be any problem, most likely just unplug the ADD electronics, zip tie the plug out of the way, stick the manual set in and go.
My options on the ’98:
I still have the stock manual hub 4:10 diff that I originally pulled out of this truck. But I will need the manual spindle/hub assembly to put back in this truck. So IF I can find a manual spindle/hub assembly I will go this route, which is what I really would rather do. (Anybody have a manual hub/spindle set lying around?)
If I cannot find manual hub/spindles I plan on putting the ADD diff under the ’98. This is where the questions are. Most swaps I’ve searched are ADD to manual, so I will need to figure out how to activate the ADD without getting overly complex and hacking a bunch of crap up.
If anyone has some leads on a set of manual hubs/spindles or info about putting the ADD into a non-ADD truck let me know. Otherwise I’ll fill in as I get the work done.
