2011 Tundra - High Clearance Rear Bumper Build
Discussion in 'Trail Toys' started by SMKYTXN, Sep 30, 2018.
  1. SMKYTXN
    SMKYTXN Vendor Vendor
    I had a customer approach me about building him a rear bumper for his Tundra. He had a few IG pictures of bumpers he liked which gave me a starting point. The main tube is 6x2x3/16 rectangular tube and the recovery points are 3/4" thick.
    The new bumper will gain him about 10" of ground clearance. The low hanging factory tow hitch is going away as well.
    Anathollo and tx_shooter like this.
  2. SMKYTXN
    Drawing and cutting the fill plates on the plasma sure makes for a clean job. I'm not a fan of feathering welds, but in this case it was necessary.
    2018-09-26 11.34.10.jpg 2018-09-26 11.55.04.jpg 2018-09-26 13.49.11.jpg 2018-09-26 14.12.37.jpg 2018-09-26 13.49.17.jpg 2018-09-26 14.12.45.jpg
    Taco Loco likes this.
  3. SMKYTXN
    Next up was the hidden hitch. Everything is behind the main tube, including the safety chain holes and power plug.
    2018-09-26 17.40.22.jpg 2018-09-26 18.17.53.jpg 2018-09-26 18.22.29.jpg 2018-09-26 18.22.37.jpg 2018-09-26 18.22.44.jpg
    Taco Loco and Anathollo like this.
  4. SMKYTXN
    Time to get started on the wings for the high clearance part of the build. They're also the same 6x2 rectangular tube.
  5. SMKYTXN
  6. SMKYTXN
    The flush mount baja designs lights are meant to be through bolted to whatever they're attached too. In this case that isn't possible, so I had to drill and tap the holes for the lights.
    I had to do the same for the light up license plate bolts that my customer provided me.
    Taco Loco and achirdo like this.
  7. SMKYTXN
    She's nearly complete at this point. I have a few more small welds to make and then it's time for paint. Oh, and then I'll get started on the front bumper.
    I was going to add gussets on the wings, but the tubes running to the frame will be more than sufficient to keep the wings in place.
  8. Silverback
    Silverback I'm not always a dick. Just kidding, go fuck off
    Nice work!
    SMKYTXN likes this.
  9. tx_shooter
    Good looking work. This is perfect timing to see you use this material for this. I was thinking about using heavy tube like this on my trail rig.
    SMKYTXN likes this.
  10. Silverback
    Question... do you build out the frame mounts in CAD and then have them cut on a waterjet or??
    SMKYTXN likes this.
  11. Anathollo
    He said plasma in the first or second post. Plasma cutting is always cheaper than waterjet.
    SMKYTXN likes this.
  12. SMKYTXN
    The rear bumper on my Taco is 5x2x1/4, and it's taken plenty of abuse. I see no reason to not use it, other than the trend of having all kinds of press braked bends in your bumper.
    After figuring out the dimensions using the foamcore I drew the plates up in cad and had them plasma cut. The cost to have them waterjetted would have been way too much.
    tx_shooter likes this.
  13. tx_shooter
    Question - on the hitch bolt hole; why the horizontal and vertical holes? Master plan or welded it in wrong after pre-drilling it?
  14. SMKYTXN
    Shh..... the first set of drilled holes ended up off center of each other. It's not a huge deal, but I didn't see a good reason to waste that piece of tube.
  15. Silverback
    Pff. reading.
    I missed that. Derp!!
  16. Large
    Large Well-Known Member
    Nice work
    SMKYTXN likes this.
  17. Oswego
    Oswego n00b
    My current bumper is 6 x 6 or 4 x 6 tube and on Rich's old taco he had the same. Using tube makes things so much easier. Just need to think outside the box during designing.
    Looks good. K.I.S.S. designs can't be beaten.
    tx_shooter and SMKYTXN like this.
  18. achirdo
    achirdo 2WD FTW
    I have a ton of 6x4x1/8 and some 6x4x3/8 if someone wants a piece for a bumper or two
    Anathollo and SMKYTXN like this.
  19. tx_shooter
    Yeah... go ahead just assume I am down for some. Will shoot you a text.
    achirdo likes this.
  20. SMKYTXN
    That's a bit larger than I usually use, but I'll keep that in mind.
    I had to source 3.5x2.5 x 3/16 today to fit inside the the frame horns on the Tundra. That stuff isn't cheap.
Share This Page
