ToyotaOff-Road.com
+ Reply to Thread
Results 1 to 15 of 15
Thread: 22Re total power loss after start up
  1. #1
    Married Man Boomtacoma01's Avatar
    Name
    Chris
    Join Date
    Jul 2010
    Location
    H-Town
    Posts
    772
    85 Yota "Lil Red"
    09 Yota "Gas Hog"
    I have been having this intermittent problem on my 85 truck. The truck runs fine after statring, then (usually going down the highway and in the most inopportune place like Houston rush hour traffic) the truck dies completely. The voltmeter shows a higher charge on the dash guage when running. I have checked all the grounds, replaced power wires to the main fuse box and all the usual suspects. I dont have any extra electrical add-ons wired to the electrical system, though it is planned in the future. I want this figured out before I do so.
    The strange thing is once I jump off the truck with a battery pack or booster cables, It runs fine and no more probs.
    What do I need to concentrate my troubleshooting on? The positive terminal has a little slack in it on the battery. Its not between the battery clamp and terminal but the terminal itself is loose ( about 1/16th of an inch play or so)
    On my list to do is have the alternator checked for proper charging and the battery itself. Is there another place I should check for parasitic drain? Would that cause the truck to shut down completely like I have explained?
    Any input is appreciated
    '85 Toyota E/C - 22-RE, 4.7's and some Marlin stuff on 37's and no A/C
    Spare Parts and heavy right foot
    '09 Tacoma DC - 285/70/17 KM2's, Kings/AllPro suspension, Shrockworks bumpers and
    sliders, ATO HC Rear Bumper, LF 170's, 1911 and some ammo - DD'er
  2. #2
    Fuck Off AlienXtx's Avatar
    Name
    Mr. Asshole
    Join Date
    Jun 2010
    Location
    Republic of TEXAS
    Age
    33
    Posts
    3,516
    Fix that loose connection first off, then like you said, have all the other stuff tested. For it to completely shut down like that sounds like maybe the battery ain't getting a good charge. If that don't work ill sell you a 22r (minus the intake etc.) For $200.
  3. #3
    Join Date
    Jun 2010
    Posts
    3,064
    Well is the battery dead? Or is it a power to the coil problem? If it dies for no reason then its not really the battery, more likely the alternator or power to the coil. The fact that it cranks back up without issue leads me to think its more ignition than battery or alternator.
  4. #4
    Kiss My IFS yotarob's Avatar
    Name
    Rob
    Join Date
    Jun 2010
    Location
    Bryan, Tx
    Age
    32
    Posts
    2,093
    05 Tacoma D-cab TRD Sport
    86 4runner "pile of shit"
    To me this problem does not add up for several reasons.
    If the battery post itself is loose then you could have a bad connection inside the battery, but that does not explain why it would die. The truck should be able to run off the alternator with out the battery hooked up once it is running
    The loose battery post could explain why it would not re-start once it dies
    If it was a bad connection or wiring to the coil or distributor then jumping it off would not work
    I vote you start by swapping in a different known good battery and see if the problem persist.
    86 pile of shit 4runner with lots of fucking dents and no build direction
  5. #5
    Name
    Chris
    Join Date
    Jul 2010
    Location
    H-Town
    Posts
    772
    85 Yota "Lil Red"
    09 Yota "Gas Hog"
    This is why I am kinda stumped. I going to get the batt and alt check out and go from there. The batt wanst dead the time before last when it happened. It still had around 10 volts on it. Its just annoying as shit when it happens.
  6. #6
    Join Date
    Jun 2010
    Posts
    3,064
    Well 10 volts really isn't enough to kick it over.. could just be something that simple. Makes me think the alternator might be taking a shit too though.
  7. #7
    Name
    Chris
    Join Date
    Jul 2010
    Location
    H-Town
    Posts
    772
    85 Yota "Lil Red"
    09 Yota "Gas Hog"
    Tru but 10V should be enough to turn on the dash lights and radio....I think?
    Davez Offroad has a 120Amp alt that is for a 22RE. Prob just going to get that one in the near future.
  8. #8
    Join Date
    Jun 2010
    Posts
    3,064
    Quote Originally Posted by Boomtacoma01 View Post
    True.. that it should. I didn't realize you didn't have anything.. I thought it just wouldn't crank.
  9. #9
    Name
    Chris
    Join Date
    Jul 2010
    Location
    H-Town
    Posts
    772
    85 Yota "Lil Red"
    09 Yota "Gas Hog"
    When the engine stops....No juice at all. It wont turn over..
    I probably should go through everything from the battery, alt, coil, distributor, wires. Maybe its something simple or maybe its not so simple.
  10. #10
    Name
    Andrew
    Join Date
    Jun 2010
    Location
    San Antonio, TX
    Age
    28
    Posts
    4,458
    Had similar problems with my wife's Mustang. A bad alternator ruined the battery, then the alternator dies and the thing would just stop randomly.
    ToyotaOff-Road.com
    Wheel It, OR ELSE!
  11. #11
    Name
    Roger
    Join Date
    Jul 2010
    Location
    Morning Glory, TX
    Posts
    434
    80 P/U - Clockwork Orange
    2009 Taco Darn Near Stock
    What was your voltage when the truck was running - it should be higher - that's the alternator working!
    I say bad battery.
  12. #12
    5 Lugger thatguy18's Avatar
    Name
    Blake
    Join Date
    Jun 2010
    Location
    Cleburne, TX
    Age
    21
    Posts
    478
    2008 Tundra SR5
    1984 4Runner - It runs!
    Quote Originally Posted by drew02a View Post
    Same thing happened with my sister's Mustang the day before we traded it in.
    Whoever dies with the most toys wins.
  13. #13
    Frack me.. SamSter0077's Avatar
    Name
    Sam
    Join Date
    Jun 2010
    Location
    Katy, TX
    Age
    35
    Posts
    1,812
    is it a Lead Acid battery, or AGM?
    Quote Originally Posted by TacoXpo View Post
    I say bad battery.
    x2
  14. #14
    Join Date
    Jun 2010
    Posts
    3,064
    Quote Originally Posted by SamSter0077 View Post
    I think its his refurbished Odyssey.
  15. #15
    Name
    Chris
    Join Date
    Jul 2010
    Location
    H-Town
    Posts
    772
    85 Yota "Lil Red"
    09 Yota "Gas Hog"
    I havent checked it while it was running. It is on the list to do though
+ Reply to Thread
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
