Let's just start with a disclaimer: It is illegal to operate outside the limits of your class license or permits
Suplemental instucitonal document http://ToyotaOff-Road.com/resources/Kenwood_TM-271A Mod.pdf
Today I modified my HAM radio to receivce and transmit on MURS frequencies. Even though the components on the circuit board were tiny, it was definitly the easiest modification of this kind that I've ever done. No need for a soldering iron, I just used these.
Remove radio's plastic cover
Unplug the external Speaker jack cover and remove the rubber gasket
Remove the 8 screws that secure the metal cover, then pull it off
A view of the circuit board and the location of resister R119
Here's a close up of the resistor. I just grabbed that bad boy with my surgical pliers and it snapped off.
A blurry shot, but you can see that the Resistor is removed
Reassembled and tested
The capacitor I had to remove on my handheld was about the size of a piece of fly shit! The only way that any tweezers would have been valuable would be to wet them to make the fly shit stick. Now just get the critical peeps to have one and the rest will fall like dominoes!
