ToyotaOff-Road.com
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 26
Thread: Leaking Pinion Seal
  1. #1
    SR5 with a TRD Sport heart CalgaryRider's Avatar
    Name
    Shayne
    Join Date
    Jul 2010
    Location
    Calgary, AB
    Posts
    176
    Leaking Pinion Seal
    Ok, I have given up on the useless forum..... I came to the real experts.
    So my issue is that I am pretty sure that the pinion seal on my truck went, based upon this picture, and the noise that is coming out of the rear of the truck while driving over 50 km/h (30 mph).
    The truck is a 09 Access cab SR5 and has 119,800 km (74,400 miles) on it and I am still covered under ECP (extended warranty)
    It goes into the shop today to get looked at, but the kicker is that most of the parts wont be in stock so, Im going to order them on my own, so that I can get my truck back before the weekend (vs. waiting till early next week)
    I was able to find this wonderful link and image (see attachment)F802090.gif, but I just want to make sure I am ordering the right parts from the dealership so that my truck is back on the road before the weekend.
    Toyota Part Sales Pinion Seal
    I am thinking I need to order:
    17 - Front Pinion Bearing
    18 - Front Pinion Seal
    15 - Rear Pinion Bearing
    I tried searching on stupid site, and just found that they were useless.
    Thanks guys
    2009 Tacoma SR5
    09 Access Cab Build
    AP Front Bumper, Skids & Spacers
    Shrockwork Slider
    MB Motorsport Rims & Goodyear DuraTracs
    OME 885 coils, Nitro Chargers and Dakars
  2. #2
    Join Date
    Jun 2010
    Posts
    3,064
    Did you try to simply tighten it? I've had my rear end leaks on occasion and I just tighten it up.
  3. #3
    Name
    Shayne
    Join Date
    Jul 2010
    Location
    Calgary, AB
    Posts
    176
    Haven't tried that yet, but based upon the amount of spray around the axle and on the underside of the box, I think it was a pretty major seal failure. I also think that the bearing may have failed too based upon the vibrations and noise I'm getting out of the rear end.
    2009 Tacoma SR5
    09 Access Cab Build
    Shrockwork Slider
  4. #4
    Join Date
    Jun 2010
    Posts
    3,064
    If the pinion is loose it will make noise.
  5. #5
    Name
    Shayne
    Join Date
    Jul 2010
    Location
    Calgary, AB
    Posts
    176
    Good to know! Thanks Sean.
    Hopefully its a quick fix, and I can get back on the road before Sat. I don't want to have to drive my gf's heep to the mountains....
    2009 Tacoma SR5
    09 Access Cab Build
    Shrockwork Slider
  6. #6
    Name
    Shayne
    Join Date
    Jul 2010
    Location
    Calgary, AB
    Posts
    176
    Which part did you tighten Sean? I was told that in the companion flange the nut is crimped to stop it from becoming loose.
    2009 Tacoma SR5
    09 Access Cab Build
    Shrockwork Slider
  7. #7
    Join Date
    Jun 2010
    Posts
    3,064
    Quote Originally Posted by CalgaryRider View Post
    On the Raisin when its pinion came loose it leaked like hell! I just pulled the driveshaft off (just the 4 bolts by the pinion) and then torqued the pinion nut back down with a 30mm socket. Then be sure to stake it with a punch so it doesn't back off again. But that nut thats crimped (its the nut that needs to be staked back down) can still come loose.. mine has done it a few times. I am tempted to put a spot weld on that damn thing.
  8. #8
    Name
    Andrew
    Join Date
    Jun 2010
    Location
    San Antonio, TX
    Age
    28
    Posts
    4,458
    I hear that having a solid spacer helps keep the pinion nut from backing off. Maybe call ECGS and see about buying the spacer from them and having your local shop install. Fix it right and fix in once
    ToyotaOff-Road.com
    Wheel It, OR ELSE!
  9. #9
    Big tires little bed taco4x4rar's Avatar
    Name
    Randy
    Join Date
    Jun 2010
    Location
    bum fuck Texas
    Posts
    1,586
    2006 tacoma
    1992 broke ass chevy
    This is a stupid simple fix, order a new pinon seal kit, (I wouldn't bother with the dealer stuff as it will be the same as the aftermarket just more expensive). Pull your drive shaft, un crimp the pinion nut and remove it take not as to how many revolutions it takes to remove the nut and remember that number, then pull the flange pop the old seal out put the new seal in and put it all back together in reverse order spinning the pinon nut the same number of revolutions plus 1/2 a turn extra to get the preload back in check (a little extra preload isn't going to hurt but too little will so a little extra is preferred), stake the pinion nut back and you're all done. Oh you should drain the fluid before you do this as it will come puking out on you if you don't.
    When times get tough - fat people get skinny and skinny people die.
  10. #10
    Name
    Randy
    Join Date
    Jun 2010
    Location
    bum fuck Texas
    Posts
    1,586
    2006 tacoma
    Quote Originally Posted by drew02a View Post
    If you staked the pinion nut solid it's not coming off, only reason seans fell off is because it was never staked in the first place.
  11. #11
    Name
    Andrew
    Join Date
    Jun 2010
    Location
    San Antonio, TX
    Age
    28
    Posts
    4,458
    Quote Originally Posted by taco4x4rar View Post
    It's actually a notorious problem with the 8" diffs
    ToyotaOff-Road.com
    Wheel It, OR ELSE!
  12. #12
    Name
    Shayne
    Join Date
    Jul 2010
    Location
    Calgary, AB
    Posts
    176
    Thanks for the info guys!
    Yeah the seal from the dealership is all of $20 so probably just go OEM.
    It sounds like the nut did come loose (might explain the hum), so hopefully its a quick and easy fix.
    2009 Tacoma SR5
    09 Access Cab Build
    Shrockwork Slider
  13. #13
    Name
    Randy
    Join Date
    Jun 2010
    Location
    bum fuck Texas
    Posts
    1,586
    2006 tacoma
    Well if it's humming, your fucked pinion preload is all out of wack if it's humming likely crush sleeve failure, time for a rebuild before the gear set grenades.
  14. #14
    Name
    Andrew
    Join Date
    Jun 2010
    Location
    San Antonio, TX
    Age
    28
    Posts
    4,458
    Sucks but is probably true
    ToyotaOff-Road.com
    Wheel It, OR ELSE!
  15. #15
    Name
    Shayne
    Join Date
    Jul 2010
    Location
    Calgary, AB
    Posts
    176
    Crap
    Good thing its under warranty, and she goes in today
    2009 Tacoma SR5
    09 Access Cab Build
    Shrockwork Slider
  16. #16
    Name
    Roger
    Join Date
    Jul 2010
    Location
    Morning Glory, TX
    Posts
    434
    80 P/U - Clockwork Orange
    2009 Taco Darn Near Stock
    I just checked in on this thread but I must say, nicely played!
  17. #17
    Name
    Andrew
    Join Date
    Jun 2010
    Location
    San Antonio, TX
    Age
    28
    Posts
    4,458
    Quote Originally Posted by TacoXpo View Post
    Glad you approve
    ToyotaOff-Road.com
    Wheel It, OR ELSE!
  18. #18
    Senior Member Lrgrnr's Avatar
    Join Date
    Jul 2010
    Location
    Asheboro NC
    Age
    24
    Posts
    1,380
    If it's still under warranty take it in to the dealer...........
    Or order a replacement 3rd setup by ECGS and get new gears if you want them!
  19. #19
    Name
    Shayne
    Join Date
    Jul 2010
    Location
    Calgary, AB
    Posts
    176
    So yeah.... still haven't heard back from the dealership, so I called and got this "They are still trying to figure out what is wrong" so I'm either getting blown off or I have stumped the techs.
    Might have to direct them to do some online research, but all I know is that I will be yelling and demanding full warranty since it doesn't look like my truck will be back today.....
    2009 Tacoma SR5
    09 Access Cab Build
    Shrockwork Slider
  20. #20
    Name
    Shayne
    Join Date
    Jul 2010
    Location
    Calgary, AB
    Posts
    176
    So I heard back on Friday about my truck (at 4pm when it went in at 7am....) and the hum was actually from the driver side front wheel bearing, so good news on the rear (not so good on the front) and yeah, the pinion seal is leaking (NO Shit Sherlock...)
    The best news is that they are covering it all under warranty The downfall is that they keep my truck till Tuesday afternoon.... so getting to work Tuesday will suck on my bike
    I am going to stop in tonight and chat with them regarding the rear axle, I want a full check done on the bearing and gears since they will have it apart anyways.
    Again, thanks for all your help guys, you gave me lots of ammunition to use against the dealership to get them to double check things.
    2009 Tacoma SR5
    09 Access Cab Build
    Shrockwork Slider
+ Reply to Thread
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
