I pulled mine a few years back, never tracked temps though.
Yeah @thekidcatcher pulled his too. I figured it'd be interesting to see if the chinsy plastic cover made a difference.I pulled mine a few years back, never tracked temps though.
So that's what causes itHad mine off for years... Don't do it. As soon as I took it off my engine blew up.
Related? You tell me
hahahaha
Drained and refilled my brake fluid. Installed my new Crown brake lines this weekend. The difference in quality between the two brake lines is unreal.
Pro-tip, when changing out the rear brake lines, cut your 10mm flare wrench in half so you'll have the room to turn the wrench.
You'll need to replace both calipers then. Typically the other one won't be too far behind it. I might be trying this upgrade in the future...I need to do this as well,and probably replace drivers front caliper as well, already bled it a few times, it sticks sometimes
That tool won't fit unfortunately. It's too long.Might be an option as well.
10mm Black Oxide 12 Pt Proto® Ratcheting Flare Nut Wrench | Fastenal
2nd Gen DIY Big Brake KIt -OEM parts- Part #'s provided (INSTALLED)
Yeah I was looking at doing that mod awhile back but didn't have the time to do the mod. I needed the truck back on the road at that point. I'll have to wait until my new OEM rotors wear out.Slick!
I've heard that quite a few time unfortunately.That's what she said. Sorry had to... I apologize.
Pretty cool. Reading that guys post you know what I'm thinking was his issue if it wasn't too much speed? His rear brakes were never adjusted to work so he fried every set of front brakes he tried. One of the guys I was camping with this weekend had the same exact issue. He checked his rear brakes at 110k and guess what? They looked brand new.
Same here.only thing I would change in parts list, I would get those green pads on oem rotors
