We have a new supplier for some of our product offerings and to celebrate, I thought we might save some people some money.
Who needs new UCAs and wants to save some money within the next week or 2? The price is too good to be advertised, so if you're serious, comment that you're interested and vehicle model/year and PM me for details.
SPC makes UCAs for:
Toyota:
1996 - 02 4Runner
2003 & Up 4Runner
2007 - 14 FJ Cruiser
1998 - 07 Landcruiser 100 Series
2008 & Up Landcruiser 200 Series
2001 - 07 Sequoia
1998 - 04 Tacoma PreRunner
2005 & Up Tacoma PreRunner
1995 - 04 Tacoma
2005 & Up Tacoma
1999 - 06 Tundra
Lexus:
1998 - 07 LX470
2008 & Up LX 570
Improve droop travel, drivability and tire wear as well as adjusting tire position in your wheel well with SPC’s adjustable front upper control arms. Featuring an upgraded greaseable ball joint and SpecRide™ bushings, this arm is designed to correct alignment angles while maintaining factory ride quality. SPC's integrated tubular and cast steel designs provide the strength and durability needed for the most demanding environments. These remove and replace arms are sold in pairs.
Get more droop travel: SPC’s arm has improved clearance to get around the spring bucket. With 80° of articulation in the upgraded ball joint and free pivoting bushings, SPC's arm gives you maximum droop travel.
Get your drivability and tracking back: When you lift your truck you affect caster and camber. SPC’s arms have +1° of caster built into them. Using its patented ball joint design the arm will get you 0° to +4° of caster and ±2° of camber, so you can put your alignmnet angles back to specification.
Get your tire where you want it in the wheel well: Use adjustment in the control arm and on the OE lower cams to maximize alignment angles and move oversized tires forward in the wheel well to minimize or avoid fender trimming.
SPC makes UCAs for:
Toyota:
1996 - 02 4Runner
2003 & Up 4Runner
2001 - 07 Sequoia
1995 - 04 Tacoma
2005 & Up Tacoma
1999 - 06 Tundra
Lexus:
1998 - 07 LX470
2008 & Up LX 570
