This is just the Ram ball mount for a 3rd gen Toyota 4Runner. Overall the install is extremely simple as long as the previous owner did not leave you any surprises. I chose to go with the top bolt location so as to keep the mounted device out of my line of sight when off roading. I may go ahead and mount a lower ball as well for use while on the highway.
Install time is roughly 15 minutes and only basic hand tools are needed. Cost will depend on which cradle and arm you select; but should start around $40 and up from there. I will install an extended USB cable for charging my phone when I run a new hose for my boost gauge.
Parts needed -
Ram mount ball for motorcycle handlebar
M6-1.0x40mm allen head bolt with washer- purchased at Home Depot for around a dollar.
Ram mount short double socket arm
Ram mount X-grip cradle for cellphones
Install -
First remove screw cover with a pocket knife or other sharp thin instrument. This cover pops out easily. The screw behind the cover should be a simple gold phillips head screw. The screw may be tough to remove so use the best fitting screwdriver that you have so as to not destroy the screw head making your day longer.
At this point I screwed in and out the new bolt so as to chase the threads to clean them up a little. After that I inserted the allen head bolt through the washer and then through the Ram mount ball. The process of lining up the bolt through the mount and pull handle into the threads was a little tricky but much easier once I chased the threads. I used an allen wrench to prevent over tightening the bolt. Once the bolt is properly snug the rest of this is simply mounting the Ram mount.
Now you can adjust the arm and cradle for personal preference -
