About two weeks ago, I finally got around to installing an E-locker out of an FJ Cruiser. I bought it used from a member on here, and had it rebuilt locally (Tandem Automotive, highly recommend) with a Yukon Gear & Axle "Master Rebuild Kit" that replaced all the bearings and seals, and replaced the crush sleeve with a solid spacer. This post isn't really meant to be a thorough DIY write-up, but hopefully it will still be helpful to those considering this sort of swap.
Removed the axle from the truck:
Removed the studs that were in the way. Second set of hands is required, small dog not necessary.
Use the new gasket to trace out the new clearance cut you need to make, as well as the approximate location of the new threaded holes.
Using your metal removal tool of choice, cut out the previously marked area. I used a 4" grinder and a dremel since my air compressor was/is broken:
Good enough:
Not many pictures of this step, but I would HIGHLY recommend using transfer punches to mark your hole location. Something like
this from Harbor Freight is only $11, and worth every penny. I didn't have any alignment problems using this method.
Also, make sure and get some GOOD size H drill bits and M8x1.25 taps. I didn't plan ahead, and had to settle for the Irwin drill & tap set at Lowe's. Since they're high speed steel, I went through four drill bits and three taps for just these four holes, even with appropriate speeds and lubricants.
Side note: Before you reinstall the axle in the truck, make sure it's in the "unlocked" position. Mine was still locked from the shop testing it. I'm going to have to wire mine up at a later date, so it's imperative I don't install a spool in my daily driver.
There was a little bit of clearancing required around the actuator side on the housing, but it was easily remedied with a grinder and flap wheel. Because of this, though, I elected to use some black RTV instead of the OEM gasket since the surface was no longer as flat as the OEM one used to be. Almost a thousand miles later, I've still got no leaks. Fingers crossed. You can also see the Low Range Off-Road actuator guard I installed. For only $40, it's pretty cheap insurance.
I would recommend removing the bracket from the motor connector. Clearance is pretty tight against the swaybar at full droop, but once that's out of the way it works fine:
Victory shot reinstalled in the vehicle:
The Sticker Cabinet of Justice is coming along nicely, too:
Stay tuned for updates on the wiring & controls. I've got a couple ideas to keep it as OEM-esque as possible.
