Nice and sexy looking. How much travel are you expecting out of that setup? What about the bump stop setups?
And damn that lift is nice.
Thanks, it turned out pretty decent. The OME dakar pack is the limiter here, we did put in an AAL into the dakar pack as well forgot to mention that, as well as do the ubolt flip. The shock relocation was part of the ubolt flip since the stock 1st gen lower shock mount is built into the ubolt plate.
For the bump stops, you can kind of see in the second to last pic. He had wheelers bump stops, and wanted to retain/extend them. I welded a tube extension to the frame then cut off the old wheelers bump stop mount off, welded a nut to the backside of that then welded it to the tube extension. The bumps aren't installed in the pic, since the hardware to hold the bumpstop on was all buggered up, so he will have to procure some more socket head cap screws that hold the bump on.
We broke the pack down and set the bumps so that he'd have around 4" of uptravel and 4.5" of downtravel. The OME leaf pack is the limiter at this setup; so the shocks don't require limit straps and theres plenty of margin to prevent the shocks from topping/bottoming out. The shocks are ADS 11" travel.
