What's in your tool box?
Discussion in 'Mechanical' started by Lrgrnr, Aug 26, 2011.
  1. Lrgrnr
    Lrgrnr Well-Known Member
    What tools and spare parts do you keep in the truck?
    I keep
    -assorted wrenches 6-24mm and some standard for the Jeeps
    -assorted sockets 3/8 and 1/2 6-36mm and some standard
    -assorted pry bars
    -4.5lb sledge
    -dead blow
    -assorted pliers and channel locks
    -pick set
    -2 jaw puller
    -4' breaker bar
    -angle grinder
    -dremel tool
    -duct tape
    Spare parts
    -3 OEM front axles
    -spare tie rod
    -valve stems
    Fluids
    -4 Q of gear oil
    -1 Q of brake fluid
    -WD40
    -brake cleaner
    -teflon spray
    -1 Q engine oil
  2. Lrgrnr
    Also looking to buy a cordless impact......any recomendations?
  3. AlienXtx
    AlienXtx Nignog
    Ask Sean about this, I believe he gas one.
    I'll list up my list in the morning.
  4. bakerla
    bakerla Man, Myth, Legend
  5. Lrgrnr
    I was looking at that one because I have the C3 drill aswell........along with charger and batteries. The 200ft lbs is what has kept me from buying it. I don't think it will be enough to loosen those stubborn nuts and bolts.
    I was dissapointed in this one http://www.dewalt.com/tools/cordless-impact-driverswrenches-high-torque-wrenches-dw059k-2.aspx and it's 300ft lbs. Wouldn't even loosen the axle nut on the truck.
  6. drew02a
    I have almost the exact tools in my tool bag. Only major difference is
    - Pry Bar
    - Torque Wrenches
    - a punch and chisel set
    - Screw drivers
    - dikes and pliers
    - bailing wire
  7. Lrgrnr
    I usually don't carry my torque wrench with me.............Something about carrying around a $350 Matco 0-250lb torque wrench around with me just bugs me.
  8. drew02a
    Mine aren't very expensive. They're the sears craftsman ones
  9. Anathollo
    DeWalt cordless impact. My buddy has one. That is a badass cordless drill. I haven't had anything stop it yet.
  10. AlienXtx
    AlienXtx Nignog
    I keep
    Hand Tools
    - assorted wrenches 6-24mm and some standard
    - assorted sockets 3/8 and 1/2 6-36mm and some standard
    - 10 peiece multi screwdriver
    - a pry bars
    - pliers and channel locks
    - tape
    Fluids
    - penatrating oil
    - 1 Q engine oil
    - Beer
    - water
    Recovery gear
    - reciever hook
    - shackle
    - 20'x 3" strap
    - 30'x 3" strap
    - folding come-along
    other
    - super syphen
    - assorted bungie cords
    - 20-30 ft nylon rope
    - ractchet straps
    - gloves
    - hand cleaner
    - bug spray/sun tan loation
    - med kit
    - .40 cal
    - knifes
    - extra TOR decals lol
  11. Lrgrnr
    Lol.......all of my recovery gear stays in a bag behind my driver seat.
  12. yotarob
    yotarob Kiss My IFS
    Just the usual tools, fluids and a spare CV. Most importantly I always have a trailer when I go wheeling.lol
  13. Oswego
    Oswego n00b
    Whats wrong with a corded impact? Ill have to try mine to see if it draws to much power, but I have broken everything from BJ's, to CV nuts free with it. It's also much cheaper then a cordless. I have run my DeWalt 12" compound miter saw on my truck and while it goes very slow it does work.....until the brake engages and pops the fuse.
  14. AlienXtx
    AlienXtx Nignog
    I dont have a "tool box" I have two bags and a ammo can, and the two pockets in my bed and the space below/behind the seats..lol
  15. Lrgrnr
    Truck will not run one at peak
  16. Oswego
    Oswego n00b
    Ill try it on the press I rented by compacting a 2x4 and then I can check it with my torque wrench to see how much it can handle.
  17. Lrgrnr
    :popcorn:
  18. bakerla
    Say what? A 15 amp saw off the inverter in the bed of the truck?
  19. Oswego
    Oswego n00b
    Yup. 15amp. Like I said it runs slow and when you take your finger off the trigger the electric brake trips it but it does work. I'm sure it's not the smartest or safest method, but in a pinch you can do it.
  20. JLink
    JLink Well-Known Member
    damn.. sounds like I need to re-evaluate my tools and supplies. I only have a small craftsman socket set with a couple screw drivers and then a bunch of recovery gear.
    Skateboards and extra crap are taking up wayyy too much space in the tool box.
Share This Page
