Will This Wheel Fit
H0LLYW00D
Active Member
I am getting redy to purchase my new set of wheel for when I get my truck lifted, just collecting parts right now. For these wheels do I have the specs right to work with a 3" Icon / Dakar Lift and 285 / 70 / 17 Mickey Thompson Baja MTZ tires
Konig Countersteer Offroad Type X
Width: 8
Offset: -10
Bolt X PCD: 6x139.7 108mm bore
Color: Black
H0LLYW00D
Active Member
i ran a backspace calc and it said 4.1 inches. so if the backspace is smaller that the stock rims then they stick out farther than stock? am i going to needs extended flares to help cover the extra width of the tires then, i live in Alberta if that helps as i know each state is different.
H0LLYW00D
Active Member
here is a calc with the stocks on the left and the Type X on the right
I think those are the rims the HBMurhy ran for a while.
yeah he ran those for awhile. He didn't like them because they didn't hold up well to offroad abuse.
I'm running KMC Enduros, HBMurphy went to the TRD "faux beadlocks".
I think they will hold up to wheeling, just not off road ABUSE.
fsbrain03
I went to an offroad shop yesterday, and he was telling me that my wheel backspacing may be causing some issues with rubbing and clearance.
I currently have Offset: -12mm, Backspacing: 4.09".
He told me that i should have a minimum of 4.5" backspacing, and minimum of 12 offset, 24mm preferred.
What do you guys think? I may have some wheels for sale if this is the case.
Yeah, Murphy said they scratched really easy (against rocks lol)
I like those rims, they look really good IMO
These wheels are fragile compared to wheels that have a beefier lip!!!
Just to be clear, I love those wheels, haven't sold them yet because I would love to put some rings on 'em. I really don't think rings would be the best either cause the lips are so friggin light weight - almost as though they were supposed to be made from steel.
They look great, are light (good and bad - seen them bust) and I don't wheel too hard - I just like to use the truck as I think it should be used!!! :)
Sean's KMC's have good beef on the outer part of the wheel - where they need it if you are going to rub up against some rocks - or curbs for the mall guys!! :)
Anyone know where I can get some 'rings' to make my countersteers 'streetlocks?'
H0LLYW00D
Active Member
would you buy them again or should i be looking at a different wheel? i want to use but no abuse my truck both on and off the roads
I have also taken an interest in the Mickey Thompson Sidebiters as well
I might but not for any off road use - They are, IMO, the best looking wheels for our trucks but one rock and you are done. I would get something that has a beefier lip!
Sean, your idea of making real beads out of my current one is a very good idea!!! :) :) :) Any money that I would save on housing by moving to TX certainly would be sucked up by having to build a new toy, I can clearly see that now!!!
H0LLYW00D
Active Member
I was looking at the Fuel Offraod Octanes but I am also thinking about the MT Sidebiters, or what other ones would anyone recommend looking to get the lift and tires on next month.
