Yea, currently have the ST Max in 255/85/16. They are sized small, not even 33" and a bit wider (32.8" x 10.2"). Getting the Discoverer ST put on this weekend. Had them in 255/85/16 before the Max and liked them. They are a true tall and skinny (33.2" x 10").
Fawk me. New tires same problem. Sounds like a rumble. Wheel bearings feel fine. Its rumbles driving straight and turning left, any slight turn to the right the rumble goes away. I wonder if it's a front diff problem....
Dang, drain and see if you have any metallic shavings?
How many miles on your WB's
It does but i think it goes away when 4wd is engaged. Just checked that too, still rumblesDoesn't the needle bearing problem in the front diff cause a rumble?
I've got 2 spare hub assemblies, been sitting in the garage for a couple years.Really thinking its a WB problem
No, i need seals...Do you have new cv seals also?
Get you a friend that lives closer by to help out, don't break your wheel sensor wires and add some penetrating oil to those 4 hub bolts tonight, they can be in there pretty tight.
Come on down. I can have those swapped out for in a few hours. I've done so many WB swapsNot too worried about the hub bolts, I had the passenger side apart easy last year. It's the heat and time that concerns me.
