Plugging A Welder into The Dryer's Outlet
At my last house I built an extension cord with these ends so I could use my dryer outlet. Idk why the welder had a 50amp plug its Max draw us only 29 amps.
I have a similar issue with the Plasma cutter I picked up yesterday. :D Didn't get to cut a hole in my front diff!!! - I was hoping to get the inspection cap in there last night!
Ahh... I read it that you had enough welder cord that you were just plugging it in.
Rewire the extension cord.
where is your fuse box?
we could just wire up a 220 outlet under it with the right plug
The tards that wired the house in 1970 did the 220 Breakers outside on a corner of the house that is not anywhere near the garage
The only thing I don't have on the dryer plug is a ground. I can grab that off of the washer plug if it's not already in the wall behind the dryer plug. Then I'll just split off the other wires to a new plug for the welder and make sure I don't run both at the same time, lol.
texasislandboy
donde esta la NGAGE IT
open up the plug on the welder and see if they used all the wires! i bet there is only 3 wires on it my dad had his electrician wire it up for me
Okay, so I turned off the breaker (then tested with my multimeter to make sure I got the right one, lol)
Then, I opened up the socket and looked at the wires. The W wire which I assumes was a neutral was exposed copper like a ground, so I tested its connectivity to the ground on the adjacent 120V socket. Tis the same circuit. Looks like I'm good to go with the conversion plug. In this case W = G
Pd3
Banned In DC!
If its bare copper then it is a grounding conductor. All 240V circuits should have a ground, but not all have a neutral.
Anything y'all need to say to me before I try this thing out and die from electrocution?
Maybe I should give someone the admin password, lol
Fuck that, call an electrician.
texasislandboy
i would still open up the plug on the welder and see if it even uses the 4 wires haha i should know this being its my welder but shit its been like 4 years
