got the ARB 3rd swapped in the other day and am currently trying to find everything i will need to get the locker up and working online...links anybody?
and if my compressor is in my tool box does it need an inline air filter/dryer?
Have you figured out how you're gonna wire it up yet? If you di it the way I suggest, here's the list (in order they'll be connected to your tank)
Rocker Switch (or whatever the hell kind of DPDT switch you feel like using)
12v air solenoid (Amazon or eBay)
90psi pressure switch
1/4" to 1/8" npt adapter (neck down for smaller fitting)
1/8" npt to bsp adapter (to connect to blue air line fitting)
So this solenoid- http://www.amazon.com/gp/aw/d/B008CPA13Q/ref=mp_s_a_5?qid=1343153420&sr=8-5
And I for the life of me cannot find a pressure switch that will work
Sent from my LS670 using Tapatalk 2
Mine is the silver thing in the front on the air manifold. This one http://sdhqoffroad.com/oasisadjustbalepressureswitch.aspx
[/IMG]
- http://www.amazon.com/Way-Position-...43244836&sr=8-2&keywords=air+solenoid+1/8"+dc1: thread it into the tank
2: connect wire leads to the control relay that powers your compressor.
then get a regulator for the arb. Set pressure switch at 120, regulator at 80 for ARB. Its how mine is wired.
