pictures of the epic RCD drop bracket lift installation that took place at Keith's shop
Rob and Keith getting it done while I assemble the new shocks
Rob cutting the crossmember with the grinder
All done and ready for paint
This is the dirt that came out of the crossmember,
The rear drop bracket going in
Comparison photo of the old spindle and new
Suspension assembled. That is one long coilover assembly. Once assembled I compared it to the 6" spacer setup I got from Andy Both measured 28", so I went with the new ones so I'd have a bigger shock volume.
All done, and a little dirty. Maybe I should wash my truck more often
Measured ground to fender at the wheel center line. It was 44" front and 43" rear, but the front has settled a little already.
When I got home I decided to paint these chrome bars black
Also installed the skid plate. It kinda suck that it hangs down 2" below the bracket, but it's better than leaving the diff exposed. For comparison I measured ground clearance font and rear. In the front, the drop bracket is 14" off the ground and the skid plate was 12". In the rear, the axel tube is 14" off the ground, and the diff is 10".
I put a 3/4" spacer on top of my coilovers since the kit was supposed to be 5-6" and my rear was already at about 7". At first I thought I might have to take it out because the front was about 1" higher, but it has settled and is level now.
I'm really happy with the results. This kit lowers the diff more than it lowers which means I can get the best possible ground clearance. I plan to get a custom skid plate so it's smooth front to back.
