Larry's SuperCoolBullbarredTribalStickered-HoodventedATRACedBrotacularWhip Build
Lrgrnr
Found 2 new bedsides......now just gotta get a virginian to pick them up :shifty:
Will replace the passenger side, remove the tire gate, put tail gate back on, and work on a bob once I get them on.
05tacoSPORT
And you are selling me thw gate correct
Sent from my SCH-I535 using Tapatalk 2
:D
How about one from the boat? :D
Nice!
2 Hands 1 Mouth
May need an extra peninsula. :)
Someone needs to throw her a beer then snap a pic
I'd prefer to take her for a drink with an umbrella in it and then bang the hell out of her. To each their own! lol
Lrgrnr
Not sure......What I did was just have a machine shop drill the rear flange out to the new bolt pattern. Let me ask Wyatt if it will fit.
Lrgrnr
On the Marlin site it says it fits 07+ FJ cruiser cases.......so I'm guessing that means it fits 07+ FJ cruiser cases.
Yeah I saw that but I wasn't sure if that meant it fit the FJ t-case or just had a bolt pattern for the 07+ FJ cruiser driveshaft pattern.
Yeah I sent Wyatt an email I think this option would be easier than drilling the flange out. Now just to find one for the differential flange lol
Lrgrnr
The t-case flanges are easy to swap, just swap them on and off with an impact.
The Diff, not so easy, you gotta re set bearing preload.
Lrgrnr
Finally put this POS back together...trucks been sitting on stands for about a month....shocks back in with new mounts and 1/4" spacers so I could let some preload off the springs to help them last a bit longer. Just replaced the springs and they are already sagging. Should have went with the 700's.
Now just need an alignment, need to replace some bulbs in the rear lights in the bumper, and need to tear down the winch and try and fix it.
Planning on going to URE or VA Saturday if anyone wants to join to see if the front end has any problems with the spacers. The UCA's hit the Coil at full droop but shouldn't cause any issues.
Just make sure you stake the nut.. they tend to back off otherwise. Then you are stuff looking for a 30mm socket at 2AM. Wait does that sound like I've done that? lol
And even if you find one, it's gonna be too thick to fit in the flange to reach the bolt... so you'll have to turn it down and decrease the diameter on a home brew lathe
