What if I cut 8" off the ADD tube, moved the whole diff aseembly closer to the middle, then installed LT CVs that were 4" longer?
I think that would give me enough range of motion to get LT numbers without the track width and less (qty) expensive parts. I would have to get a custom ADD shaft though. It might be easier to dump ADD all together and get super long custom CVs and center the diff,
I could probably afford to sacrifice a little travel at that point to lift the diff up so the bottom doesn't stick out under the Drop Bracket.
.I could probably afford to sacrifice a little travel at that point to lift the diff up so the bottom doesn't stick out under the Drop Bracket.
