Primate Labs Test Subject - 1991 Pickup - Codename: The Raisin
Ok, so I picked up a new rig. Not so much a project since its damn near ready to go. But it will have substantial changes along the way. Its a 91 Reg cab pickup, bobbed and dovetailed, only straight sheetmetal is the stuff that points to the sky. Its seen its share of trails but its a solid rig. Built with the good stuff.
Details
22re Motor rebuilt with less than 5k
MC07 Dual cases w/ rear case 4.7:1 all Marlin Crawler.
Marlin Crawler Dual t-case crossmember
Hydro assist setup from redneck ram
Front axles feature an 83 Front axlehousing w/ TG ball gusset kit, and Truss.
Front and mini Diff armor plate.
30 spline longfields (with chromo hub gears)
Spool
5.29's
Trail Gear 6 shooter knuckles & arms
High Steer kit
LC Vented Rotors
new calipers
1.5in spacers
Rear axle is a Trail gear Rock assault housing with large inspection cap
All Pro uboltless spring perches
Sky Offroad Disc brake kit with large vented disc brakes
Spool
5.29s
Suspension
Front has built 84 RUF to match rear springs 3in lift.
Marlin Crawler SA Shackles.
Rear is TG 3in Springs.
Bilstein 5125 shocks up front and Poly Performance BBCS out back
Full interior cage
Sport style seats
4 point harnesses
Fire Extinguisher
CB
Inclinometer
VisionX Tantrum LED rock lights
Small tool box in the bed
The bed has been bobbed 1 foot and dove tailed 2 feet.
Tires are 38x12.50 TSL Sxs on 15x8 rims with Staun's internal beadlocks.
Some pics
Autometer oil pressure gauge.. powered by B&S decal :)
Longfield Birf shift knob and dual marlin knobs. Also note the hand throttle control on the shifter :cool:
Six Shooter knuckles. I need to get under there and clean and paint everything.
Seats are comfy!
Dual valvestems, one for the Stauns and one for the Swampers
VisionX rocklights
It is missing something
Next to the Taco
Things I must do before I can wheel it
Driveshaft for the rear. Debating between a square tube or round. Square is just noisy.- 2.5"x.25 wall square tube done
New battery.. the Optima that was in it I gave away with Clyde. I'll be picking up a Platinum. - Platinum - done
New Power Steering belt, it squeals pretty bad under load. Might need a new pulley as well. We'll see. -New PSC hydro assist done
Then the things I 'want' to do.
Replace the steering wheel... that OEM wheel is horrible. Time for a wheel like I had on Clyde. - Grant wheel added along with new column trim - Done
Add a handle to the rollbar to ease getting in and out. - Done
Marine cupholders!! This probably should be in the "Things I have to do before I can wheel it" category. :D - Done
Add the stereo components I had for Clyde. Sony marine headunit, Polk Audio marine amp and Polk marine speakers. - Done - went with iPod interface for head unit though
Install the Cobra 29 CB I have, along with the Firestik and other CB stuff. - Done
4Xinnovations Tube doors - with kickout - Done
12-15 gallon fuel cell in the bed. - 15 Gallong RCI fuel cell with Artec mounts - Done
HiLift mount -- once I complete the bed
MAYBE new front sheetmetal... maybe. - Done
Taillight housings with lens (just for looks really so its REALLY low on the list) - - Pulled bed and built flat bed
Paint.. flat gray - Done
New winch.. Warn M8000 more than likely. - Done went with Superwinch 8500
Might go with a flatbed/backhalf cage at some point - Done
RuffStuff 7/8ths Hiem steering with 1.5x.25 wall drag link and tie rod - Done
Sky Mfg Chromo pitman arm - Done
TG Chromo flanges with ARP 2000 studs - Done
Corbeau 3" harnesses - Done
New radiator and fan are in the garage awaiting install
I bet your neighborhood collectively facepalmed when that was pulled off the trailer...
Look forward to seeing it in person.
Especially since its spooled F&R so turning on pavement is not something it likes to do. LOL
I'm planning to have it ready for HF on the 15th of April. Should be very do-able to get it ready.
Screw the new sheet metal get one of those ftoy body's from Hendrix motor sports.
I've thought about it.
Link to the build thread on pirate?
can't find the build link.. I found the for sale link.
Can't wait to see it in action, you just got dangerous...lol
me either!
The thing is so freaking flexy.. just moving it around it wiggles like Jello. I've got a shitload of Swamper tracks in my driveway because of the spools, it just leaves marks as it goes. :)
Nice rig Sean, I really like the Addicted off-road front bumpers, that is what I hope and plan for mine when the time comes.
Thanks Rob.
Well I had to order the raw 2" ID seamless tubing off the web. Isn't sold locally... well I suppose I could buy a 2' hitch extension and cut it up. But I'd rather have the raw steel to start with. Anyhow, square tube driveshaft project is going to be underway as soon as it arrives.
