What I dont have:
Headunit Done Apline CDA 105
Subs
Sub box
The rear storage bins from behind the second seat. I took them out a while back and my dad must have chunked them
What I do have:
Amps a JL 500/1 and 300/4
Stinger distribution blocks/ RCA's, misc power and grounding wire
Raamat Sound deadener
Alpine Type R SPR17-C 6 1/2" components for the front and 2 way 6 1/2" for the rear
Mr Marv speaker rings
Parts to check out:
Soundoff audio sub boxes Just need to decide if I want a single or dual sub setup. I have run JL and Orion Subs in the past and really want to go JL again
I got rid of the Kenwood Double Din HU that I had. A buddy wanted it worse than me
I'll probably pick up an Alpine CDA-105 from a friend 3 sets of RCA's and other decent funtions to ease the wiring up a little.
I have the Scoche DD face mounting plate but will need one for a single DIN HU. Done
I will deaden the fuck outta this thing before anything is installed. Rattles bug the shit out of me.Rear done
I know some of you are running the Pioneer and Fosgate shallow mounts, But Id rather stick to a somewhat standard depth sub or figure out some way to make and 8W7 work in a downfiring orientation.
Ideally, I need to find someone who is getting rid of their stuff (possibly over there) and maybe I could find a deal.
What are yalls thoughts on converting the under storage compartments to speaker enclosures?
I just wanted some suggestions from the guys here and if yall se any deals link them to this thread so I can check them out
Subs
Sub box
What I do have:
Parts to check out:
Anyhow.. you have the amps and components.. get a headunit that has good clean outputs with high voltage (4v or better). Look at the Alpine shallow mounts or the JL TW5 series (Pioneer dumped the Premier line and the replacements are stupid $$). I contemplated replacing my Premiers with the Alpines but I can't justify the cost.. not to mention I was only going to do it because I "thought" they might sound better.. never heard a pair. My Premiers sound pretty fucking good. A few folks on here can attest to that. But I also supplement the mid-bass with some 8's in the doors which does help with that mid range punch to the throat. The JL TW5's are a great speaker.. but they are not cheap.. a single 13W5 behind the seat would be pretty awesome.. 2 would be even better.
