TheKidCatcher 's Build
BirdTRD
beLIEve
I don't really get the inside joke here but it sounds like I should stick with ordering the 90000's.
Eric had 5100s cranked all the way up, with 885 springs then proceeded to break shock on a speed bump.
BirdTRD
beLIEve
Oops, that was definitely a bad idea. Wrong way to go for the 5" lift.
I did just help a guy lift his truck a couple of weeks ago. He had 885's and wanted to put his 5100's at 0.85". I figured that was ok but definitely the limit.
I'm doing 886's though. I think I'll just stick with the original plan of getting screwed out of 300+ dollars for a set of shocks.
Good Idea.
night_angel
How is the 886/5100 combination? I've usually heard that's a no no. I currently have eibach coils and 5100's and I'm switching to 886's and 90000's to support the new front bumper. I already have the coils sitting in the garage and I was planning to order the shocks soon here but if the 5100's work just fine, well then...
I have the 886 OME springs with OME shock... and it is very hard... and before, I also had the Stock Bielstein shock with 886 OME and it was harder...
I would stay with the 885...
885's with OME shocks are a great ride with the stock bumper.. But add weight like a bumper/winch and they fall flat. I had that setup.. Went to 886's. It was a stiffer ride but it didn't sag.
night_angel
Tenemos caminas buenas pero nos gusta las piedras!
claro, pero ustedes tienen poca velocidad sobre piedras..., mis caminos son feos, en casi todos los lados y con una suspencion dura, con el tiempo te cansas... y queres algo mas suave y comodo...
perdon por desviar el topico TheKidCatcher! =D
true...you have much good roads also... I not...
No habla por favor :)
IMO the worse the road the better for the stiffer spring.
BirdTRD
beLIEve
Es verdad.
Kidcatcher, lo siento tambien.
night_angel
Jason, have you a catalytic converter?, I see you have
- JBA headers
- JBA exhaust
- JBA midpipe
- Volant CAI with optional scoop
- URD MAF
, as I have no catalytic converter, constantly "check light" is turned on,have that a solution? had you this problem?
I am interested in buying these JBA headers, tell me about it...
nice truck...our built`s are very similar =D
thekidcatcher
I still have all of the catalytic converters in place so I dont have to worry about that lights coming on. Forgot to take off the volant with scoop as I now have the snorkel haha. I like the headers and would recommend them. Not a primary accessory but if you have the money and want that little bit of power then go for it. I think it helps a lot with my mileage with all of the extra weight on the truck.
