Picked up a new Klein screwdriver
Avoid hinged miter saws. They are not accurate saws because of the hinge. Also get a "shadow-line" miter saw. It helps with your cuts so much. But any DeWalt or Makita miter saw is going to do you really well.Recommendations for a 12” miter saw?
Don’t have a huge budget for it. Under $400 would be best. Sliding would be preferred but not necessary if it takes it out of my price range. Single bevel is fine.
DEWALT 15 Amp Corded 12 in. Double Bevel Sliding Compound Miter Saw, Blade Wrench and Material Clamp DWS779 - The Home DepotRecommendations for a 12” miter saw?
And choose a free stand to go with it.
Oooooh I’ll probably have to get one of these. I’ve seen some really bad reviews of the Pro Eagle for the price. Will have to see how these compare.Well Harbor Freight is releasing this knock-off of the Pro Eagle jack. So I'll be picking up one of these bc the pro eagle jack uses shit components and charges a premium price.
I have both of those and they work greatPawn shop finds today, $15 for the pair.
I have both of those and they work great![]()
Installed refurbished Netgear Orbi WiFi 6E routers in my house today. I shouldn't have waited this long to upgrade the routers because the wifi speed is amazing.
Yes, I have the satellite router hardwired in for slightly faster speed and my Fire TV & camera system is plugged into it as well. Everything is almost instantaneous now which is really nice. I didn't realize how bad my Apple routers lagged until I got the system.I did the Linksys about a year ago and regret waiting as long as I did.
I assume the ones you got have ports on the back where you can plug in a rj45 cable. Those devices use some sort of back channel that is faster than wifi if you can plug something in. I'm darn near gig speed when connected direct to the hub.
AX4200Which model Orbi did you get?
