285 KM2s
Hows your trail rig coming along? Serious question.
It's been neglected. Worked on it last week hoping to maybe take it to Jambo. No dice. Still have weird brake issues. So I ordered a new prop valve thinking that was the issue. Haven't tried it yet. Hard to get much time to work on it when it's an hour away.
Overkill much?
Probably but I was tired of seeing my bed rails crunched so I figured I was only gonna do it twice lol
Plus I had a spare 3/16" plate of scrap steel lying around so I put it to use rather than just rusting away outside my shed haha
This should keep the bed rails from crunching again, just need a few end caps and some paint
Brakes "should" be an easy issue. Are you sure you have bleed them completely? Go spend $20 on a vacuum bleeder.. or do what I do.. I simply crack open the bleeders and let it gravity bleed for a few hours. As long as the reservoir has fluid you won't be introducing air into the system. Gravity bleed and then use the vacuum pump.
I'm positive they've been bled correctly. After talking to Bob a little bit tonight about the issue, I'm pretty sure the new prop valve will be the answer. Just have to find time to get down there and put it on.
Last minute mod tonight. Wired up some rear facing lights I was not doing anything with. Should help with backing up, setting up camp or those ass holes that ride my ass in the dark. I know Sean said they glare off the tailgate, and they do but also put out light to the sides since they are angled slightly.
We'll move those things down low Aaron.. just say when.
I think I can manage that. :)
Good looking stuff! :)
Swapped out both calipers in the front. Turns out my driver side was seized and my passenger side was missing the top pin holding the brake pads. I was also missing both clips that are on the bottom. Truck rides so much better now lol
One of my calipers is missing the clip holding the pad in.. i just used safety wire.
Get that man some more light where it matters!
