I figure I'd be pushing it or limit the height I could lift a vehicle.
How tall is your ceiling with your lift? Anyone. I have 11' and want one, just not sure I have enough ceiling height.
So how long till Bendpak delivers a shiny blue lift to your house?
So that second picture is the 10 3/4 ceiling with the lowpost? Thats not bad at all. I'd need to install a kill switch on the ceiling to keep from smashing stuff up.If you don't mind, what did that low post run ya? Anything special to install it?
It was 2600 installation runs 300 , but I did it and nothing out of ordinary. Hammer drill and hand tools
Yeah,my first lift the big one took two old guys in there fifties an hour to do. They rolled up with it on a trailer and they slide it off lifted the post by hand ,longest part was burping hydraulics
forgot about the hydraulics. Damn rum
:oJambo is on the calendar if the tow rig decides to play nice, having injector issues at the moment. Are you going Sam?I always wonder what happened to "that guy"...You going to make it to Jambo?
Walls are 14' and total peak is about 17'.... lift is 12'6' inches but I found some low rising ones that would fit in a 11' ceiling just won't work well with full size trucksHow tall is your ceiling with your lift? Anyone. I have 11' and want one, just not sure I have enough ceiling height.
Ill take some more pictures later today! I just built hinges out of angle iron and the left side has to hinges with 1/2inch bolts holding it in place. The right side has one hinge built the same but it has a pin that replaces the bolt with hole in the bottom that i can put a lock in and you cant get bolt cutters tooLets see some detail pics? How does it latch?
Also, who knows the best epoxy for the price? I am planning on doing about 25,000 sq ft of epoxy and haven't begun to look. Thanks for any imput.
Read up here... lots of opinions and whatnot. http://www.garagejournal.com/forum/forumdisplay.php?f=20
I went with Epoxy-Coat and was very happy, but I am getting a small spot thats lifting where the Tacos tires park. So I need to contact them and see about fixing it. Not sure if it was my fault or what as to why its lifting.
http://www.epoxy-coat.com/
