Depends, personally I wouldn't have just one air system if I was running an ARB, I would have their mini compressor or whatever it's called that is just for the locker and nothing else and it would be dedicated to running the ARB and ARB only. Then I would have a second unit for all the other OBA needs, including but not limited to actuating the ARB should the dedicated ARB compressor fail.
Not a bad idea. I have my Oasis which is a monster.. and way overkill for an ARB. It works great and when I have engaged it I've always had to turn on the Oasis and fill the tank.. not a big deal.. takes seconds. But a small dedicated compressor would be nice to eliminate the need to crank up the big dog. But if you are only going to run one then go big.
