Fuck it was hot today, got another good chunk knocked out.
Red loctite applied to flywheel bolts and torqued to 100 ft-lbs
A little trick I learned working solo, use a pressure plate bolt and chain it to the bell housing mount in the motor to keep the flywheel from spinning when torquing it down
First clutch disc
Intermediate plate
Outside clutch disc
Red loctite applied and pressure plate bolts torqued to 45 ft-lbs
Made sure both of those discs are lined up perfect to themselves and the pilot bearing or else it will be trouble trying to hoist that heavy fucking trans up there.
Also had found that the transfer case shift lever has two bolts that secure it to the linkage, one of them was missing. The threads were stripped out so I guess the previous owner said fuck it and ran with just one. That's alot of leverage for just one small bolt, so I tapped the top hole to 5/16-18 and used a grade 8 bolt I had lying around
Put the grill back on
I have a buddy coming over tonight to help me install the trans. Once that's in it's just re-connecting the driveline/shifters and some small stuff in the engine bay. Should be finished by tomorrow night
First clutch disc
Intermediate plate
Outside clutch disc
