Like the title says - '87 4Runner with two snapped off lug nut studs. My question is do I have to diassemble the free wheeling hub when removing it from the axle hub to replace the stud?
Way to contribute to the thread![]()
I figured you could smack them out and replace them.. I haven't ever seen the lugs on an 87...:o
At least hit it with a hammer to see if it will come out before you go to all that trouble
If it won't come out easily it will have to come out hard. IT has no choice in this fight. Hell or high water it is coming out. I am going wheeling Sunday at Bridgeport.
4 studs should be sufficient to wheel one trip as long as the 2 missing ones aren't adjacent
According to Chiltons - I can. After I remove the pull the brake caliper, remove the free wheel assembly, remove the outer bearing, pull off the brake rotor, and then remove teh lug holder from the brake rotor. Really it isn't too far from my old '92 F-150; but it really is different overall.
This ^
I know it sounds like alot of work but it's not, a 1 hour job at most. Might as well clean and repack those wheel bearings while you are in there.
You and the freezer...![]()
It's all about the press.
