More updates
Got the rear shocks 95% done. The 1" body lift helped out alot with getting these suckers to fit, otherwise you'd have a tough time fitting 12" shocks inboard of the leafs without going through the bed.
The reason I wanted to inboard them was to keep the bed preserved (at least for now
) and I don't have a bender to make a shock hoop for the outside of the frame and I wasn't paying anybody to do the work cuz I'm cheap LOL. Also I haven't seen too many 2nd gens with this mounting configuration. This also allowed me to retain the stock mounts if I ever decide to go back to the stock location for whatever reason. The whole setup cost me ~$80 in parts minus the shocks
The icon shocks I had in the stock location were 25" at full extension, not sure what the compressed length was but they were about 3" too short for my rear springs. They were made for a 3" lift so they say
Axle mount welded up
Under the axle tube, my upside down welds seem to be getting better
Upper hoop, 1.5" 3/16 square tube with 1/4" shock tabs for double shear, shouldn't have to worry about any flex with this setup. I notched the composite reinforcement under the bed so I could get the crossmember up as high as possible.
I then made the top hoop disconnectable in case I need to weld another tab on or change anything up so I don't have to redo the whole thing.
Resi mount for one of the shocks, welded up to one of the crossmembers behind the gas tank
Painted everything up
Axle all painted and shocks mounted, ran out of daylight so I'll have to flex it out another time. shocks ended up around 35* at ride height, they are valved a little stiffer to compensate for the angle.
I have about 3.5" of shock shaft showing at ride height so I should be good. At least now I won't have to worry about the shock being my downtravel limiter. Got everything buttoned up and took for a test ride, everything seems pretty decent and the ride is smooth.
Picked up a 45* turndown from vato zone and a clamp, total cost of $10 haha, it'll do for now and keep my shock resi from burning up.
Drivers side just about fully stuffed, still some shock travel left so I don't have to worry about bottoming out the shock. Passenger side still has another 2" of downtravel or so
Also replaced the zerks in the shackle bolts and regreased them. The one that come with the trail gear shackles are junk and failed after a short while.
You can see the shackle isn't quite verticle yet so I still have some downtravel left on the passenger side
Passenger front not fully stuffed yet either
