Well my wiring is about 95% done. Only thing left to do is mount the winch solenoid pack under the hood and run some wires to it!
Here's a few more better pics from my camera rather than phone showing how I fit the 6 switches overhead. Like I said there ain't no room up there, I cut out most of the sunglasses holder but it still seems like it's holding up pretty well
View from the side showing how high the wires stick up. I tried to tuck them in as best I could but with the heat shrink and daisy chain there's only so much bendin' you can do to get these bastards to fit
Configuration of the switch bank
All the wires hooked up to the switches. Ran 18AWG for the lights and illumination and power circuit. For the winch I wasn't sure how much power the solenoids drew so I ran 12 AWG for those two switches. I left plenty of slack in case I need to troubleshoot in the future or re-splice or change anything around. Also notice I put small labels on each wire end, that will be key along with the schematic for tracing out any future wires
Everything tucked up there with the console bolted in. The ARB harness comes in through the passenger side
Here's where I spliced into the stock positive and negative terminals. Took them down as far as I could and butt spliced with 2 AWG and tinned them then heat shrinked.
Here's a closeup of the mil spec terminal, this bad boy is beefy and allows for multiple hookups of larger gauged ring lugs
Earlier tonight I took two test videos in the dark, not the greatest quality it was raining and I didn't have much light to work with but I was impressed how fast the compressor filled up my tire, I'd say slightly over a minute to go from 8psi to 34psi. That bad boy does draw some amps tho!
[video=youtube;TcI2CnpytMw]http://www.youtube.com/watch?v=TcI2CnpytMw[/video]
[video=youtube;2qrJNKnxdzE]http://www.youtube.com/watch?v=2qrJNKnxdzE[/video]
