Much awaited picture of the tent open after flipping the trailer axle this morning. The tent is still high; but only "expo van" tall, not skyscraper tall. The ladder extension from CVT will fix the ladder issue. Once I can put the motorcycles on there to confirm the necessary clearances and load distribution I may be able to drop the tent another 6 to 8 inches. That will have to hold off till v3 build; but overall clearance for the motorcycles is a critical requirement for overall function of the trailer build.
I did see a guy's build where the front tent bolts were on hinges. The rear of the tent would be "bench pressed" up and then pinned in a higher position so the motorcycles could be loaded underneath it. The angle was not a lot but enough to get clearance.
As for the height of the tent; it is lower than a bumper pull 5th wheel would be. Side note; it will be nice to be able to use the annex this trip. Usually the wind is the biggest issue for trying to cook out there; so the annex will give us a sheltered place to cook and will warm up nicely to change clothes, blah blah blah.
