That's all I have left I think
I have been putting in a bit of work lately.
I cut the outer rail and Kickouts off of my sliders. They stuck out way too far and were more of a hindrance than a blessing on my past few trips. I will refit the Kickouts to reweld to the rear of the sliders. I also trimmed another 2 inches off of the front of each slider. The 40's kept digging into them at full stuff and on hard turns.
I stripped down the interior of the truck in preparation for the Auto Swap.
I have pulled the Duals and am in the process of pulling the transmission. I have them sold and should have enough to drop on an Atlas II 4.3. I removed the clutch peddle, slave cylinder reservoir, hard line and starter.
I found an A340F at a local yard for a decent deal of $300. I ordered the Advanced Adapter 50-5710 adapter to fit the A340 to the Atlas. I also replaced the 3 solenoids in the Transmisson pan and need to install the Transgo 340 HD2 shift kit after the new valve body gaskets come in.
I also ordered some miscellaneous brackets and tabs to make the transmission crossmember. Dave @ Brave Motorsports is going to Fab up one of his tail housing supports for the Atlas.
Since my truck was a manual and will be keeping the stock wiring harness, I went with the RADesigns Baja Shifter to manually control the transmission and the Rock shifter for the trans gear selection. Iwill have to fab a mount for the 2 shifters and adjust my transmission tunnel cover accordingly.
I will be adding an external TransCooler (Derale 13950) and ordered all of the -6 fittings and hose to plumb it in.
Parts buying should just about be done besides ordering the Atlas..
Damn I'm broke..Time to get to work.
A340 with the R series bellhousing
Swapped out the solenoids
Trimmed down the sliders
Cab cleaned out
Down to 2 peddles from 3.
Ready to drop the transmission.
