Oh. For any others that may have that problem or the ones on the t-case think about this:
someone on Yotatech :D said:
My factory e-locker switch was missing a pin and rather than spending big bucks on a replacement, I used a reverse light switch.
And yes, please shim as required! :D
Jandrews
From what I can tell in the FSM, ToMoCo uses pretty much the same switch for all these applications, it's just the specific plugs/wiring that are different.
Paying for convenience...wasn't the first time, won't be the last.
Do you know the p/n for that puppy?
I pulled one off my spare T-Case for Sean and would be glad to donate another to you if you want to cover shipping
yep. Thanks again Drew.
That would be FABULOUS!!! pm your paypal email.
New fuel and water cans. Need to paint the green one red... can't have that Rover green on a Yota. It causes diarrhea.
I also have a plan about where to locate them in a secure fashion. Once the Raisin is good I'll start on that.
Sexy stuff! No Louis Vitton? lol
They where fresh out. But I'm hoping to get it painted. :)
damn.. and that response was entered using Google Chrome. Time for a reboot. lol
Update with recent crap
"stretched" the rack 8". Simply cut it in half, sleeved it with some 1.5x.250 wall tubing (leftover piece from my high steer on the trail rig).. welds, grinds and presto.
Added an 85 watt solar panel to charge the spare battery, the one the ARB fridge runs off.
Solar panel bracket built and installed up top under the bed basket. Should work fine without any gear up there.. which at camp won't be an issue.
Added VisionX utility lights on the sides and some others out back. Can't remember the mfg of the rearward facing ones. All of them are LED so current draw is at a minimum.
Nice!
Looks good!! to protect the $200 solar panel, you can always add a sheet of Clear Lexan Polycarbonate for protection since it is under the cage.
You might find it cheaper at a glass shop.
http://www.homedepot.com/h_d1/N-5yc1v/R-202038065/h_d2/ProductDisplay?catalogId=10053&langId=-1&keyword=LEXAN&storeId=10051
Thats a good idea. There is a good inch between the two right now, but the rack is aluminum and I noticed that it bends fairly easily. Some protection is in order... or a new rack.
Brown delivered some stop fast goodies.
Time to replace the EBC green stuff pads and rotors. The rotors are slightly warped and they wanted $75 a pop to turn them at a machine shop. Normal brake lathe wouldn't cut it. (dimpled/slotted)
Old
Anyhow, PowerStop Extreme Truck/Towing brake package. Found a good price on the set.
New
Looking forward to opinions... Your earlier choice made a marked difference in braking of my truck. Before I felt like I was throwing an anchor out the back.
