Shop Cleanup - Coilovers, H1s, LSx stuff, Seats, etc
the_white_shadow
Cleaning out my shop and am selling some stuff that is in the way. Some are from when I swapped tons under my toyota and others are from when I swapped in the LQ4. All are in good condition unless noted.
All prices are OBO.
Text at nine.79 250 three niner three 5 for additional info and pics
Pics can be found here.
Shop Cleanout - Rock Crawler Parts, LSX, H1s, Griffin & C&R, Coilovers
Located in East Bernard (77435) but can deliver to Houston area (West) for free during the work week.
Stock Chevy Dana 60 Parts
1. Stock Disk Brake brackets in good shape. I have a set of calipers that are good for a core that I will throw in for free. - $80
2. Stock Spindles that are rusty but could clean up. Threads are straight - SOLD
LSX Swap Parts
1. Griffin Aluminum Radiator. Bought less than a year ago from Summit Racing (Part # 1-2572-x. Too big for my new build. 31x19x3 Crossflow. - SOLD
2. C&R Racing Radiator - I bought this bad boy used on EBAY with the intent to use but never got around to installing it. As you can see in the pics it does have a few bent cooling fins and does seem to have an old repair to fix a leak. No idea if its a good fix or not as i never even put fluid in it. It does have a built in trans/oil cooler/heat exchanger with AN fittings. - SOLD
3. Hooker Cast Manifolds - New in box. I painted them and baked them with black VHT coating. Never used. Summit racing Part # 8501HKR - $200
4. Truck manifolds with EGR block off plate - $50
5. LS1 Corvette Manifolds (A couple studs need replacing) - $100
6. LS3 new takeoff manifolds (Not Pictured) - $125
7. LS3 Drivers side manifold (Pictured) - $50
Crawler Parts
1. H1 Beadlocks with cut down magnesium Runflats. One wheel is missing 3 studs. New studs can be purchased at Trail Worthy Fab for cheap. All are in excellent condition - $175
2. Gm Truck 1-ton Master Cylinder with Sky Manufacturing Toyota adapter. This allows you to bold up a 1 ton master to a stock toyota brake booster. Fittings are included but not the SS brake lines - $70
3. Hunsaker Sport Bucket Suspension Seats. Vinyl is starting to peel off, but they have no rips or tears. They recline and have sliders. $100 for the pair
4. Random Bucket Seats. Not sure the vehicle these came out of. In great shape. - $40
5. Profender Coilovers x 4 with Springs and Reservoirs. 2 - 16" and 2 - 14". They 14s are about a year old and the 16s are about three years old. One of the 14s has a bent shaft, but a new shaft from Profender is included. All shocks have nicks and scratches from mounting but the shafts are clean. The coil springs on the 16s and on one 14 have been rubbing on the shock bodies, as seen in the pics.
$1,100
They are dirty as seen in the pics, but I will power wash them for new owner. All of the coilovers hold pressure and dont leak.
Spring rates:
14s:
150/200
16s:
100/150
the_white_shadow
Let me get a pic of the seats I am buying for the front and see how well they match. I will shoot you a PM when I do.
