Got a new bench to clean up guns and tinker with them on. I like it. Needs a vice though. Drawers are nice to organize all my shit in.
He texted me the information. Basically its a non-patroleum based lube (smells awesome) that for best results you heat up the parts before you coat them with it. You also have to degrease any components prior. Then wipe down after about 90 minutes... only bad thing I've read and know a friend who it happened to was this. On Nib (Nickel Boron) components, in my buddies case the BCG, it caused the NiB coating to just flake off. Disputes about it being a bad NiB coating or the Froglube can be found on both sides. I don't have anything NiB to worry about.
Oh and I'm not doing the second coat today... fuck its miserable outside.
Yes... anything in the BCG/barrel gets coated. Even the trigger assembly if you have one you can disassemble. @Anathollo can speak better to what is required though.
I use both. I use the paste to apply the first three coats and the gel to do light applications.Do you use the liquid or the paste? I have both but I need to get some small brushes for the paste.
