Gotta love planting cheap and needing to wait years for the bulbs and grass to grow and flower. Some of the grass won;t even sprout till this fall or so the wildgrass instructions said. Yep.. we tried a bunch of things to keep (sparkly hanging things, some other shit I forget) the birds from just pecking a fucking hole in the good ones. Someone said to put a bird bath near the tomatoes because they poke holes in to get water and not really to eat the tomato. Not sure if true since we have a fucking pool 60' away. Lazy fucking birds.We built a chicken wire cage over them last year, kinda a bitch to get in and clean out weeds and whatnot but the birds stayed out.
These zucchini plants have been in the ground a bit over 6 weeks now, how many will fit in the garden box?
What about one of those fake owls?
Probably 2. Maybe 3.
They work for about an hour. I have a few up in my shop and after the first hour or so the birds completely ignored them.What about one of those fake owls.
Chiminea developed a crack in the side. I researched on google to see what I could use to patch/repair it. Some sites suggested that a 2-part epoxy could be used if other (better solutions) like bondo weren't available. I had some on hand, so decided to just go that route.
Since I had to lay it on its side to get the epoxy to set, I decided to go ahead and sand and paint the base.
Now I just need to figure out what I can put on it to protect the clay. Based on some internet reading and what the paint that was on it is doing, I'm guessing it was painted after it was fired. The paint has disintegrated in some spots and flaked off in others. This has left the clay exposed in some areas. I need to figure out what to put on it to protect it. At this rate, it only has a few years of use left. I'd like to find a brownish high temp paint, but copper is the closest I've found.
you have a big enough yard for a good size garden...
Yes, but HOA sucks. We aren't technically allowed to have one at all. We are a golf course lot, so even though the lot is about 30' above the golf course it is still considered viewable from the course. Hence the small raised bed alongside the patio. Something is better than nothing.
you will have fun with that golf course/HOA neighborhood, do you have the nextdoor app?Chiminea's are disposable items like outdoor grills are now. But fire it up and see if that epoxy patch will hold with the heat.Chiminea developed a crack in the side. I researched on google to see what I could use to patch/repair it. Some sites suggested that a 2-part epoxy could be used if other (better solutions) like bondo weren't available. I had some on hand, so decided to just go that route.
We had those up under my plant along with a screeching owl speaker that was on 24/7. The speaker finally died and noone has requested to replace it because it did fuck all. I actually think there's less pigeons in my plant now that the call is off
