I’ve seen them. Think I’m just going to use some raceway.Check into the cable hiding options on Amazon. I installed 3 in the house and they are nice.
I don't do residential anymore (other than my own house), so I don't know that much about new framing designs with lumber. But looking up the floor joists number off the labeling on it, 16" PWI 47 (highlighted in green), I found the specs online. Based off the load it's supporting and how far the joist spans determines the On Center (o.c.) spacing. Per the chart from the manufacturers website below, it can be spanned at 12"o.c., 16"o.c., 19.2"o.c., or 24"o.c. (highlighted in blue).@Anathollo
A new 2 story a few houses down from me, 24" center beams for the 2nd story floor??
Probably 1/2" since it's residential. They don't give a fuck if the sheetrock fails after 5 years from improper spacing.Would be curious what sheetrock they are using though. The sheetrock specs are tighter than 24" studs.
Yep, I'm not a fan of those floor joists but the tongue & groove floor sheathing will also add strength to floor joists as well. Will these homes last a 100 years? I doubt it but then again, we don't build homes to last here in America.It just seemed sketchy.
Just a follow up on this purchase. I’ve used it pretty much everyday since I bought it and I absolutely love it. Haven’t found anything I need it to do that it’s not capable of doing and it’s nice only needing the one tool and being able to swap out the check to do whatever I need it to do. I can keep the drill bit in the drill chuck and a driver in the hex chuck and just swap the whole thing out as needed rather than carry two tools/batteries with me to do the same job. The only gripe I have with it is it has little push buttons on the top to switch the direction. Wish it had the normal push switch by the trigger. There’s no quick way to rally switch the direction on this thing without taking your hand off the grip.
Settled on a gutter company for the new house, I should have new gutters installed within next couple weeks.
Working also on finding a slab/metal building company for the farm.
I don’t know how close you could get to a match with the other pulls but could you do one of the hanging (best word I can think of) pulls on those two corner drawers? If it was low profile enough to fit in that recess, the other drawer wouldn’t hit it when it pulls out.Finally got around to putting handles and knobs on kitchen and bathroom cabinets and drawers etc, The Laundry Fairy is much happier.
These dumbasses when they installed the cabinets, they didn't use a corner spacer between cabinets, so one drawer can't have a handle or you can't open the drawer.
View attachment 46316View attachment 46318View attachment 46319
