Make sure your CV axle nut is torqued properly.
did you check torque values on all the new stuff? Sometimes they like to loosen up.
if you have soot build up you have grease exiting it and that's sometimes a sign they are starting to go.
173ftpdsYes, I have checked every nut or bolt that I've touched.
This is why I've been looking at torque wrenches that go up to 250 lb-ft. Mine stops at 150 and I believe the manual calls for 176 lb-ft. (odd number, but that's what sticks out in my head) I got it to 150 and then gave it a good umph more.
Might be better to get a jump on it, I only have 26k on it.
That's why he gave you that deal I bet, knowing you'd prob up grade anyway or getting rid of old stockI just got this email from them tonight, funny how that works![]()
X2 @CowboyTaco I was so tired last night I forgot to add this. It's sounds like the carrier bearing. I had the same issue and couldn't find where it was coming from. @SecretSquirrel diagnosed it immediately when we were putting my truck into drive and reverse in his driveway.how about the carrier bearing, those things are about the worst design I've seen on a truck. They tend to get floppy and squeaky after a few thousand miles. A few things you can do to try and eliminate what might be causing the noise.
1 - remove rear driveshaft and put truck in 4wd. See if noise stays the same or goes away. That will eliminate the rear shaft
2 - jack truck up and remove the coilovers, put truck in 4wd and let truck throttle out in 1st gear. Have a buddy turn the wheel while you jack one side at a time from the LCA working the suspension full travel.
I've found that doing these two things you can find the issue 99% of the time if it is indeed a driveline issue. Other squeaks could be from body mount bushings, or the stupid dust shield rubbing on the rotor.
Carrier bearing should be your next check. Easy enough to see if it has play.Alright, jacked it up got the tire spinning as fast as I could and then abruptly stopped it to change direction. Didn't hear any clunking.
Now what?Nice and clean View attachment 14384
Now what?
Bolt it all back together? :shrug:
Why did you pull the valve cover off?Why did you pull the valve cover off?
Ahh ok, please tell me you did the other side too?
You needed a fat guy like me pulling on it.
