My Tk1 Racing sway bar came in. Initial impression was great overall quality. Fit an finish of the aluminum arms were nice with tight tolerances. Sent a few pics into to Tony to check out my arrangement then made a few changes based on his expertise.
First iteration. Everything is setup at 50% travel of the coilover (ride height). I set the arm level to the earth and my end links were 16" (Same as coilover travel).
Kinda hard to tell, but the axle mount is offset 2" outward.
2nd iteration was after sending pics in to tony. the arm is angled up more at ride height.
After drilling holes in my frame, I installed a 33" piece of 1.75x.120 tube and installed the swaubar without the end bushings as they were a tight press fit into the tube and i havent fully welded it yet.
Same 2" angle at the axle end.
Checked clearances at full bump. The arm clears the tubing with some room to spare.
I then tried to repeat the setup on the passenger side. This is where i think i ran into an issue with the swaybar itself. I couldnt get the angles of the arms to match up, so i took the bar out and came to the conclusion that the spines are off a few degrees off on either end not allowing the arms to stay at the same angle. I am assuming this is a flaw. I emailed tony late last night with the pics below so i will see what he thinks. Maybe im overthinking it.
One side is perfectly level on the table.
Other side not so much. If i go the next spline the other way, it gets even worse. This is as close as i could get it.
Gap underneath.
In the meantime while i wait to figure this out, ill fully weld in the tube and brace it to the frame front and rear.
