achirdo
2WD FTW
What don't you like about it?Sig 2022 sucks balls. Don't buy one. I own one and haven't shot it in years. I need to go trade it in...
From all I've read online and seen, I would wait a little longer for them to develop better barrels for the Valk or I would just go 6.5.Grendel. The majority of what I've seen is guys are only able to pull off reasonable MOA groups below 77gr bullets. Well if that's the case then I'm going to go ahead and shoot a .223 77gr which is a helluva a lot cheaper and a proven cartridge.
Also, any data you see out of a bolt gun for the Valk cartridge, just throw that data out the window. This is a Semi-Auto cartridge and it should perform like they said it was going to OUT of a semi-auto. If you're going to build a bolt gun in .224 Valk than I'd recommend you pick a better caliber (6.5Creedmoor, 6mm, .260, etc...).
Striker fired guns are not my cup of tea
It is but it gets used and abused!
In that case, go with a 6.5G and you'll be happy. Ammo is cheaper too.Yeah I've seen it go both ways. I'm still giving it a bit of time before I jump all in on it. But honestly, I will never stretch it out as far as some people are. If I can get consistent in the 800ish yard range, I'd be happy. Not going to to be pushing for 1200+. Luckily, until I buy the barrel and bolt, I'm not committed and those will probably be the last things I buy anyway. So at any point I can change it up.
It's a cheap POS with Sig's name on it. It's picky about 9mm ammo selection and the bore axis is so damn high on it. I literally have to aim like 6" inches over the targets head at ~15 yards to get a head shot IIRC.What don't you like about it?
Come shoot my Glawk and XDM with my custom triggers and you might find you like em. I can't believe it's been two years since I posted that video already...damn times flies by.Striker fired guns are not my cup of tea
I'm trying to get you out of that Marine "Make Do- even though I can get better stuff" mentality that they trained/beat into youI am a cheap ass. My old school double sock and beans setup has worked well over the years. At some point it will get upgraded/replaced but until then it is doing the job.
I had these opinions well before this video was posted and they were confirmed by these guys results. If you don't watch all of it, watch their final conclusion at the end.
This is a ballistic chart showing the difference between a 12.5" 6.5G barrel versus a 16" .223 barrel. So you can see how badass the 6.5G round is.
Yeah that's pretty impressive. May have to look into that for the next AR buildIn that case, go with a 6.5G and you'll be happy. Ammo is cheaper too.
I haven't shot a p2022 yet I only have my 2 p226s I thought it was the same except the poly frame.It's a cheap POS with Sig's name on it. It's picky about 9mm ammo selection and the bore axis is so damn high on it. I literally have to aim like 6" inches over the targets head at ~15 yards to get a head shot IIRC.
It was my first firearm purchase at 21 years old when I knew nothing about firearms. I went in wanting a Sig 226 but couldn't afford it so I got the 2022 thinking "it's a Sig, it'll be great quality and comparable to the 226". Wrong. It doesn't shoot anything like the 226 and I shoot the 226 like a laser beam. But that's my opinion but there's probably a million other people telling me I'm wrong.
Edit: But it's your money and your guns so buy what you want. I just want y'all to buy the best you can for your money and not waste a lot of it buying dumb/bad gun parts or guns like I do.
We do amazing things with "acquired" gear. There is a reason nobody let's Marines on their base without keeping an eye on them.
That was only $100? Saw this at harbor frieght, should be getting it for my birthday soonI've had a $50 Cabelas gift card stashed away in my wallet since last Christmas. Got another $50 one this Christmas so I picked up some nicer cases for my rifles. 52" Plano All Weather for the Weatherby and the 42" version for the AR. Was hoping I could get the 10/22 in with the Weatgerby but since I put the Magpul stock on it, it wont quite fit. Ahh well, I'll just keep using one of the cheap cases I have for it. It doesnt need anything too fancy. I plan to pick up one of their smaller all weather cases as well that will be able to hold 4-6 pistols.
View attachment 12787 View attachment 12788
9800 Weatherproof Protective Rifle Case - Long
This is the Tactical Trigger in my Glock in the video.Are you using the PRP in your XDM?
