How is your sas coming along Randy?
Roger K here...
I have tested, okay that may be the wrong description - I have brutalized my truck with and without ATRAC. I have found the limits to the ATRAC. If I knew where the video was and wasn't too embarrassed to show it, I would show you my test data!!!
Lockers that engage and disengage quickly are by far the best. ATRAC is, IMO a great backup and will get you home.
That is all.![]()
Roger K here...
That is all.![]()
Open / Open..........FTW![]()
Well looks like I have a bigger problem than ubolts. Seems my 5150s are going to be to short. Should be getting the leaf pack in tomorrow to make final dimension and see where every thing is going to land.
...Any thing bad w running these together?...
Well every thing came up short. The bolts were long enough to get about half the nut thread w no washer or bump stop. Ran to autozone but the ubolts they had seemed really cheap and thin so I'm going to run to a fastener store tomorrow and see what I can get there. Plus these leafs moved my axle about a half to an inch closer to the cab and killed my driveshaft angle. Where do you get the axle relocation blocks to move it back a little bit? I got a good felling it moved it far enough forward that im going to hit the wheel well. I already have some angle shims I'm going to throw on as well to keep potential vibs at bay. Any thing bad w running these together?
As for the shocks... looks I'll be getting some new ones if I can find some long enough that are eye to pin. They came up about an inch short
) but they are good. You can get them at a77 pr0. Shocks? you may want to try FOAs - great price for what you get!... I got them by a non-reputable dealer () but they are good. You can get them at a77 pr0...
Kinda hard to mess up pieces of machined aluminium, but I'll bet those fellas could figure out a way to mess it up with their special brand of engineering.
For my knowledge what is the cause of this? Is this partially due to your shackle flip?
My best guess is the leaf from front eye to the axle pin is shorter. The flip will not have affect as it only follows where the leaf extends too
I didn't realize this was common with the Dakars. Thanks.
Mine actually lined up perfect! My a77 pr0 ones on the other hand were not as precise.
