Just Relo@ding
I do not have any hands-on experience with Lee but there really are not any "bad" reloading presses between the Lee, Hornady, or RCBS in that category.
Picked up the absurdly priced primers from local shop. Have ~500 9mm cases ready for powder and projectile. Just need to setup the bench and start pressing away.
For how little I reload, the single stage is fine; but I'm sure I'm going to be wishing I had the progressive press when I start getting it going again.
Hopefully just scored 200 pieces of Starline 6.5 Grendel brass from MidSouth Shooter Supply. Will see if they ship it in the next few days.
Score! MidSouth just shipped the two hundred pieces of Grendel brass.
Some more precious metal investments arrived. These were even $5 off each box which made the buy that much nicer. I was happy just to find them in stock for more than a few hours.
Added an upgrade to the reloading / maintenance equipment since I have a few more suppressors on the way. The rotary tumbler with stainless pins does a nice job on brass but is a bit more work than a vibratory tumbler.
And then the dehydrator got some use.
A month ago (roughly) I went to do some reloading and could not find my calipers to confirm case trim lengths. Of course I got annoyed and stopped.
Recent conversations with @tex about reloading gear got me to thinking about that issue. So I applied the patent-pending @Silverback Solution! Now I have my original one, plus a other nice metal one, plus 3 decent abs calipers.
I have 3 calipers now. 2 digital and 1 analog. The digital is easy, but i like the feel of the analog more. Something about that dial and the gauge.
But the most important part is to buy a high quality feeler gauge set and test the calipers on them. You'd be surprised how far off they can get across the jaws. Even had issues with Mitutoyos before being a .0001 out of spec.
When I worked at that turbine shop, we had precision grinders (specialty trained guys who take a .0001 off material at a time) that would have to certify new calipers and measuring equipment.
Stopped in at Cabelas today to kill some time to discover they carrier an annealing & brass prep station I have been looking at. I used my vet discount to knock a little off the cost. It has been a great addition to the reloading gear already! I processed chamfering for a couple hundred 6.5 Creedmoor cases really quick with zero hand pain; which was great! Next will be getting the annealing figured out to improve case life and loading tension.
I also went through the "range collection" bucket to sort out some 7mm-08 for @tex . At this point I have enough 45-70 brass to get a rifle for it. lol I am still saving 50BMG for the time I decide to start reloading for it; but that is all new presses and such.
