There are better scope mounts out there than this one... Also, unless you plan on moving your scope around or using it in combat (where you'd need to take the scope off to get to your backup irons) then I typically don't suggest quick mounts anymore. The extra weight and the extra money doesn't make em worth it.Buy a quality, quick release scope mount, LaRue is the only brand I recommend and use the same optic on different AR platforms, after zero’d in, just record what weapon with corresponding windage and elevation specs
