Tools!
Those are cool! I just hang my Milwaukee tools by the belt loop hanger on my dogs kennel. However he does not use the kennel any more so I need to take it down. These look like a great option.
I like that it gives me some options to maximize usable space. This keeps everything in one general area and easy to keep track of.
Anyone used an air tool holder like this? Are they worth while or are there better ways to store air tools/ devices? Still working on organizing the garage. I have preformed metal material like this and could easily drill/cut to do this if they are worth while.
eBay link
eBay link
i have a similar one from a guy on Etsy, I believe called speed fabrications. I just make sure to put caps on the air lines to avoid dust from getting in there
They make various plates to hang the tools.
I am using these off Amazon. An electrician friend of mine recommended these exact ones. He uses them in his work boxes without issues.
Amazon.com
Then I received these last night for the M12 tools. They are made in Texas and are a pretty firm fit. I may end up sanding them a touch to be an easier on/off fit. If I was using them in a trailer the retention fit is perfect right now.
https://www.amazon.com/dp/B07RXDB6HC?psc=1&ref=ppx_yo2_dt_b_product_details
Awesome. The search begins for Ridgid holders.
eBay link
Which one, nylon or aluminum?
I looked at the Husky cart in the store yesterday. Absolute junk. No way I'd put $100 into that one. Pulling the drawer out and shaking it probably had a good 5-6" of back and forth.
This came in today, should make removing the ford fan clutch much easier next time around, and good general use pulley holder/strap wrench. Uses a standard 5 rib belt and a 1/2” drive breaker bar. Not sure why nobody makes these anymore but any new strap wrenches I’ve seen are cheap plastic and won’t hold up if you swing your purse at it
What is this? Was under my air compressor, but there is a trash can nearby. No indication that it is from the air compressor.... or anything else for that matter.
I hope you are joking and actually know wtf that is lol
Better look for a flat tire with no valve stem cap lol
You probably picked it up in your tire tread at some point and it fell out in your garage.
If you just want a good cart that will last a lifetime all the tradesman in philly use these to get their tools from the parking garages to the jobsites that are blocks away.
We also used them daily in our shops.
Never seen anything fail on them other than a wheel that's easily replaced.
Also made in the USA so no supporting commies
First tool I've bought in months. Sadly its commie china made but every pro I know uses them. Same as the cart in terms of well known reputation in the commercial pro market.....just sucks there is no US equivalent available with the same reputation.
I guess I can kinda feel ok seeing as I bought it at a local store in town for $5 less than Amadongs best deals
I've made a lot of money with my pole... lol
But also buy a roller with ball bearings (usually the most expensive roller on the shelf). Made a world of difference when rolling out paint. I just made sure the roller is spotless once I'm done using it and that it dries out.
So funny you say that. I blew another roller out yesterday. That's three this year I've killed. Two on the basment block walls and one priming/texturing/painting a bedroom.
I never even knew they had them with bearings. Wish we had this conversation a few hrs ago before I got back from the store with another generic sw roller lol
