Show it some love before you throw it away.
It's not a bad hub. It's a bad bearing. Not sure of the quality of the Dorman crap but the border in me says keep it.That is the bad hub so I do not care about it now.
Yeah - part of me says keep it to rebuild it. Part of me says I already have plenty of spare parts that do not require rebuilding.
Attempted to swap out some lower ball joints on a 14 T4R Sunday. Two things went horribly wrong. One, AC Delco ball joints don't fit right. You can't get the snap ring to seat in the groove. And two, it came from New Jersey, so the driver LCA cam bolts were both seized. So next weekend is cutting them out. Grease dem cams boys, all it takes is one n done.
NJ rust sucks.... Yeah, the 5th gens have the same setup as the GX470s do and I believe they're actually interchangeable. In the GX world, 99% of people just replace the entire LCA with OEM when the ball joints and/or bushings go bad. About $700. But the ball joints are damn near impossible to replace and a lot of shops won't even do it.
NJ rust sucks....
Wait until the second set of BJ's goes bad on the LCA's. I have yet to see a aftermarket LCA BJ that will allow removal once it's installed. The aftermarket replacements I have seen do not allow enough room for a cup to slide over them for removal via press. Seem they are all a little bigger diameter.
I was able to remove Moog lowers, had a big half cup i used with the press. The AC delcos removed easily, but still, they weren't going to work without removing some material from something.
Ohh Moog, POS parts...My Moog lower ball joints lasted all of 20k miles.I was able to remove Moog lowers, had a big half cup i used with the press. The AC delcos removed easily, but still, they weren't going to work without removing some material from something.
Good to know. I put moog in many years ago and the full cups I had would not fit. Silly me - I never tried a half cup.![]()
I've got the ball joint/u-joint removal set. I'll get a pic of it for ya if I remember and get a pic of the half cup I used.
