10mm isn't gonna cut it. I would have to stack 6 of emOME sells a lean correction spacer for like $15
Rear Trim Packer for 2003+ 4Runner, 2007+ FJ Cruiser (150PR10)
full tank of gas? maybe the front lift shifted the distribution of more weight to the rear? Maybe you broke something in Colorado?So the 4r has a bad driver side lean. The front isn't bad, maybe 1/4" but the rear is awful. Driver rear is 1.5" lower than the passenger rear. Suspension is stock in the back. Any ideas?
Just re-read your post. 1.5" sag on the driver side sounds like something broke. Have you given it a visual inspection?
I know a guy who recently took his factory springs off a 2018 with 2k mi on the odo. I bet he'd come off them cheap if you determine it to be the spring. I don't know what would effect the suspension height that much outside of the spring.
I made use of the spare mounting parts from the roof rack and used some extra long wheel studs to make mounts for the traction boards. Overall they were a lot cheaper than the Tred mounts and work for my needs.
I have a stiffer woody now than when I woke up this morning!Got new tires today. Upsized to 285/70/17 BFG KO2 in load range C.
Took advantage of a Labor Day sale and they warrantied 1 of my old tires towards the new set.
Pretty sure @tex needs to coat those in tire shine for UV protection!![]()
yesh I know, just trying to preserve your recovery gear,Then they will be so slick they will not work as traction mats!
My secondary Plat still running strong 2012, I think the solar panel helps
Sucks you had a warm beer. Sucks more you have dead battery. Easy enough fix so get to it.
I’m not messing with battery/truck this wknd, I’ll buy a battery on the next sale I find.
This wknd is reserved for sitting in the river, and drowning in Praise Jesus Coldbeer.
I was taking ARB out anyways for the RV.
Went to go pull a Praise Jesus Coldbeer out of the ARB fridge and got a 74* Praise Jesus Warmbeer...
Ran this battery for 6 years. Damn good battery and solar setup to keep it going.
Mounted up the Roam Adventure batwing tonight with the new mounts I setup. The location worked out nicely so I fully opened it up to check it out with the rear hatch. There was a little issue there but it can be resolved. My issue tonight is that I found a few small holes in the awning material. I emailed Roam and will see what they have to say tomorrow.
