lol :shifty::machinegun:
Guess you should have stayed in your own tent in AR, your ass is probably still sore.
No.. barely felt a thing. I'd say it was like a roll of dimes but that's giving you too much credit. That being said.. I didn't push back.
MatthewMay1
amateur professional
Replaced the oil cooler and new orings and gaskets on the tow pig. The 7.3s have a common leak area here when the orings get brittle. It looked like my truck sneezed out a negro when I started it out in the snow last week lol
Messiest job to date, had to drain oil and coolant and shit still comes out of the log as there's no direct way to drain the heat exchanger.
View attachment 8458 View attachment 8459 View attachment 8460
I'm jealous of your shop
We all are. :)
Appears I blew out the inner boot on my drivers side RCV axle. Must have snagged it last weekend at the farm driving down to the creek on some mesquite. Anyhow, ordered a set of boots from RCV (damn things are darn near as much $$ as buying a spare axle.. no shit.. $46 a pop). Also ordered a new trail spare axle. The plan is to replace the axle with spare. Rebuild the axle in my "free time" and then redo it. I need to get the truck inspected before the end of the month so that is why I ordered the spare. So hopefully it warms up a smidge tomorrow so I can clean up the garage a bit and get it ready. I also ordered new UCA bolts (the long bastards) and I have new uniballs sitting here so once I get the CV rebuilt I'll be rebuilding the UCA's as well.
Edit... posting this here so I don't lose it. :)
So my damn CV boots are not in yet.. will call tomorrow as they were supposed to be here early last week. Anyhow, I decided to pull the old and replace with the new trail spare. I will swap them back out once boots are here and rebuilt. But I sorta fucked myself. When I installed my Kings I had someone help me, and they managed to use a SAE UCA nut (the one that connects it to the spindle) and threaded it onto the lower shock mount bolt. I said fuck it at the time because I wanted it done and it was not going anywhere.. he got it snug! Boy was I right. In order to pull the CV I needed to disconnect the lower shock mount... or pull the bump stop.. it would not slide past either. Bump stop is a Wheelers Super Bump and it uses an 8mm allen to get it out.. bolt is way up inside the rubber stopper. Normally I pull it when the LCA is completely down using a longer allen key or one on a socket. So I decided to pull the shock bolt since the normal way to pull the bump was to disconnect teh shock anyhow. Ahh but I forgot about what happened before with the wrong nut and that thing just spins now. Either way really.. plus I had a dirty ass CV axle right in the way. So I cut down an 8mm allen key and inserted into a 3/8 8mm socket and viola.. worked great. Its out, I plan to cut down another allen key and weld both into a 3/8's socket, one for the trail bag and one for home. Now I really wish I had a parts washer.. thing is nasty!
True.. just to find a spot for one. I have a spot i just need to remove the steel storage that is in its place.
Also, this is something I should have addressed when it happened. I got kinda lucky in that I was able to cut down a allen wrench to allow it to work in the shop. Had this needed to be replaced on the trail it would have been a real PITA as I normally don't carry a grinder with a cutoff when out and about.. I do carry a hack saw blade but it would have taken time as that allen key was hardened metal. That being said I now have a tool to allow it. But it was sloppy of me to not replace that fucked up bolt when I knew it was fucked up. I should have addressed it right away. I'll be ordering a new one (or 2) tomorrow.
My favorite parts washer was my college apartment's dishwasher. We hand washed all of our dishes and when I was rebuilding an RD400, I would put parts in the dishwasher, start it and by the time I came back from class or woke up in the morning, all the parts were clean and dry. :) lol
Boy I got a deal for you, bring all your tools down my way, and you can use my parts washer and your tools anytime.
Man that is a deal!! But I think I'll just spend a couple bones and get my own. I do appreciate the offer though. :)
I was going to suggest that you can always get ugly ones for free but the idea of flushing down the drain wasn't all that great.
Yeah, not gonna install a dishwasher in the garage... unless she is cute.
