the problem is that I upload most of my photos from my phone and then come back and edit the post from the computer. It's just easier that way. The downside is something you get HUGE images.
Wrong thread?This little guy showed up on our porch a couple hours ago. Apparently he hung around outside all last night and we didnt know it. We're at maximum capacity with our two dogs but he made himself at home for a few hours until my girlfriend can take him to work with her this afternoon (she's a vet tech). Think one of the vets there is going to take him. Doenst beling to anyone on our street and judging by how hes been taken care of, whomever had him doesnt want him anyway. Hes well fed but has fleas, worms, and who knows what else. If we didnt have two dogs already, we'd keep him. Hes super cool. View attachment 24012
Wrong thread?
Paging @italynstylion for audio info.
I thought about using MDF, or any wood for that matter, but wouldn't that swell with moisture? The inside of the doors not exactly the driest of locations, I figured wood would be a bad idea. Maybe using an old cutting board or something similar to achieve the same idea.
So @Silverback votes for the most expensive option.
First question would be do you have a subwoofer @CowboyTaco ? If you do NOT have a subwoofer then I'd say stick with the 6x9s in the front. The reason is you will have WAY more cone area to move air which will likely translate into more bass. Doesn't mean you can't get good bass from a 6.5" driver, but when you're on a lower power budget, you need all the cone area you can get. This is because cone area translates into efficiency. Case in point, the 6.5" component set is 92db efficient and the 6x9 set is 94db efficient. This means they will play that loud when given 2.83V of power which is typically 1watt at 8ohms but since those are 2.3ohm speakers it cheats a little. I won't get too into it but just know the 6x9 is drastically more efficient and will do better of lower power from a headunit.
Whoever said that MDF will swell when it's in the doors is correct. A cheap plastic cutting board is best if you aren't sealing the wood. I used to offer MDF baffles with an option to seal with roll on sound deadener paint to keep that from happening when there was water in the doors. Works great.
The decision about the tweeter is a tough one. My suggestion would be to simply bypass it but leave it in place. The reason is the tweeter will use some of the available power and you will likely have an overly bright sound that you can't tame with the limited EQ functions the headunit will provide.
As always, yes, an amp will certainly beef things up but I wouldn't go there unless you do the speakers first and THEN still want more. But before doing that I'd suggest deadening the doors and sealing up some of the holes in it that are close to the speaker itself. You'll want to really ensure the back wave doesn't interfere with the front wave of the speaker to keep them from cancelling and reducing the bass.
PS: Thanks Zech for summoning me on FB.
Meh.. just go for it. Get a sub... and a couple amps.. and ... and ... Its like any upgrade, how much money do you want to spend and at what point do you want to be when you consider that upgrade complete? Sounds like you are comfortable with the 6x9's.. good, save some coin. If it was me I would have done the 6x9's and then realized I should have done the 6.5's and a sub and wasted money on 6x9's.![]()
After I did a lot of sound deadening work in my doors I noticed just how bad my speakers/headunit are. Really wish I had upgraded everything all at once.
